I got tired of waiting for my repaired ribbon so i could complete my main speaker project so I decided to start working on the quitech transformer in a box.
This thing is huge!!! 90lbs and 12" in diameter !!! ![]() 10 guage OFC wire for internal hot/neutral and +60/-60 wiring, ground will be with standard 16 guage hookup wire ![]() Power cords for connecting to/from the transformer: Carol 10guage 3 conductor wire with marinco hospital grade IEC and 3-prong connectors. ![]() Leviton 8310 Isolated ground outlets and Panel meters to measure AC Volts and current. I tested the voltmeter on my wall socket 125V rock solid ![]() Of course a project of this magnitude can't be worked on alone.. Here's Cassandra inspecting the panel meters to make sure their operating correctly. ![]() Step 1: Modify the leviton outlets by removing the ears so they can be installled closer to the edge. ![]() Picture of the modified outlet. ![]() Test mounted the first socket, the hole was cut with a 1 3/8" bi-metal hole saw... ![]() Looking pretty good so far, I'm still waiting on the filters which should arrive tomorrow and then I'll hopefully have one working socket to test --Chris |
#2 |
Think this belongs in solid state doesn't it?
| I need car MP3 Player Project ( using old PC part ) | pasan | Car Audio | 2 | 19th March 2007 03:31 AM |
| My Fostex FE 108EZ project, Part 2 | Taperwood | Full Range | 21 | 13th April 2006 02:48 AM |
| What type of part is this? My amp project :) | darren01 | Parts | 20 | 14th June 2004 10:18 PM |
| My p3a amplifier project, pics. | Jean | Solid State | 13 | 8th December 2002 03:00 AM |
| Need help finding simple part for project | d-audi | Tubes / Valves | 7 | 29th October 2002 11:47 PM |
| Page generated in 0.08417 seconds (67.17% PHP - 32.83% MySQL) with 10 queries |
