Hello there! I am creating a pipe-in sound system for our showroom that needs PVC pipes as speaker enclosures for ceiling mounted speakers. The ceiling speakers would still be hanging from the ceiling but i need an enclosure to be mounted on the steel deck ceiling to house the ceiling speakers i've bought.
I need to know: 1. How can this be done? Is this idea ok or do i need to make a box instead? 2. Would the length of the PVC pipe matter in terms of sound quality? 3. Would the sound quality be good for soft ambiance music and paging? 4. Has anyone done this already? 5. Is there a need to make port holes on the end of the pipes? |
#2 |
as i discovered investigating transmission lines. There are a few things you can do with PVC to make your own TL's with drivers of the proper size.
Persistence is better then intelligence. Unless persistence kills you. |
#3 |
It is very likely that the speakers are designed not to have any box, just mount them in the ceiling. What does the manufacturer recommend? If they recommend a box, then just get PVC of the same volume and close the end.
Everyone has a photographic memory. It's just that most are out of film. |
#4 |
L = 1.2 M for 40Hz
(Its like a folded transmission line with an 'abnormal' termination :-) |
#5 | |
#6 | |
If you do make a box with PVC then yes at a minimum you'd stuff some polyfill at the other end to prevent reflections off of that flat surface from coming back and hitting the back side of the speaker cone and negatively affecting your sound. Also, stuffing a sealed enclosure can increase the effective volume by up to 20% or so. Regarding ports, you need T/S specs (Vas, Fs, & Qts) to determine whether porting makes sense or not along with the proper box and port sizes.
#7 | |
http://www.yorkville.com/products.as...d=228#overview Unfortunately i've contacted the dealer and there was no specs sheet found in its box. The dealer told me that there is no need for a bass reflex port and the length won't matter for this kind of speakers. But i just wanna make sure so i will also refer to you guys. TNX! |
#8 |
There are several DIY PVC-pipe enclosures here on the projects page, as well as plenty of links to transmission line design theory and worksheets.
I imagine you can easily adapt one of them for your application. Dave
I have a small website for my projects. |
#9 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
Tnx for the advice and the site you've recommended.
However, my last concern would be if it is a good idea to put dampling material inside the pipes or do i just leave it empty and seal the whole thing? How much damping material do you think is needed? I am now creating a prototype for this project. I am going to use an 18 inches PVC to be mounted on the ceiling with the use of a circular MDF boards, 4 screws and silicon sealant. My ceiling speakers goes into the other end and is also sealed with sealant. |
| Speaker Enclosure | rudy129 | Multi-Way | 1 | 21st May 2009 03:52 PM |
| speaker for 2 litre enclosure? | Nanook | Multi-Way | 5 | 13th May 2007 02:04 AM |
| WTB: Speaker enclosure | Destroyer OS. | Swap Meet | 5 | 3rd October 2006 06:48 PM |
| How do I know the best speaker for an enclosure? | dohhhhh6 | Subwoofers | 2 | 3rd June 2005 05:19 PM |
| Right Sub for Speaker Enclosure | Xyberz | Multi-Way | 3 | 9th September 2002 12:03 PM |
| Page generated in 0.12386 seconds (79.25% PHP - 20.75% MySQL) with 11 queries |
