#21 | |
Tom, the LDC is right. I've got you had microphone 1/4" in front of the cone. Thus I think that I've written the BS did't affect measurements. Sorry for messy czenglish
Tomáš |
#22 | |
The Butcher |
#23 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#24 | |
Hear the real thing! |
#25 |
Then can't you just make the speakers very shallow and wide, then mount them on the wall? Won't this greatly reduce the need for BSC?
#26 | |
frugal-phile(tm)
dave
#27 |
yep, I built 2 sets of speakers using identical drivers, one pair are 50cm wide and skinny, to go against the wall, and need no BSC; the other pair are made from 30cm pipe , baffle width 21 cm, and they defintely need BSC, even though they're hard against the wall.
Currently I'm using Rod Elliot's line level BSC, but probably will eventually put in a big inductor
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#28 |
One thing to keep in mind when using BSC is that at the same volume level setting, you will have less output. So in order to obtain the same listening levels, it's probably good to check if you have sufficient Xmax to support the same listening level you are used to.
#29 | |
Cool, that means I'm learning I now wonder why do most the designs I've seen, in particular the fostex bass reflex recomended enclosures, are made narrow and deep? Being able to go crossover-less / filter-less is one of the main advantages of fullrange I thought. |
| Short TL as Baffle Step Compensation | m@ | Multi-Way | 0 | 10th March 2008 09:07 AM |
| Baffle step compensation formula? | bart_dood | Full Range | 4 | 8th July 2006 10:50 AM |
| Baffle Step Compensation | Khron | Multi-Way | 4 | 16th April 2006 08:23 PM |
| Passive baffle step compensation | noodle_snacks | Multi-Way | 5 | 10th October 2005 06:20 PM |
| Baffle step compensation in an active X/O | sunil | Solid State | 6 | 12th November 2003 09:52 AM |
| Page generated in 0.09463 seconds (84.39% PHP - 15.61% MySQL) with 11 queries |
