sealed vs. ported
sealed vs. ported
Old 8th May 2005, 04:02 PM   #21
sonu is offline sonu  India
I rechecked the thiele paras, given by elliott sound and i got the following results results,
FS - 29.6
VAS - 284
Qes - 0.61
Qms - 7.46
Qts - 0.56
But before testing, I had a break in for the driver.
Second thing, is the Qts high because i have used a 8mm thick top plate and the coil is 35mm lenth, which gives me 13mm of linear xmax, and only 8mm is in the magnetic gap.
Old 8th May 2005, 05:08 PM   #22
Somebody please reply,
Old 9th May 2005, 03:52 AM   #23
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
sealed vs. ported
I don't know that much about speaker topology, but I do know that 8 mm is a very common value for the magnetic gap, (air gap). That is not unusual at all.
0.56 is not an unusual value for Qts either.
To make Qts lower, as I stated before, make the magnet larger.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 9th May 2005, 04:34 AM   #24
richwalters is offline richwalters
richwalters's Avatar
Break point for reflex tuning is drive unit Qts lower than 0.4......above that go for sealed box.
However nothing is imposs. You can use a highish Qts speaker and put it in a large box and keep system Q around 1.......depends on your usage.
You can put a high Qts drive unit in a small box with alot of damping.........not recommended unless for MI apps.
Your VAS suggests a large box..however do the math first.
richj
Old 9th May 2005, 12:19 PM   #25
Wizard of Kelts
sealed vs. ported
FS - 29.6
VAS - 284
Qes - 0.61
Qms - 7.46
Qts - 0.56
YOU said that you test these in a 2.8 cu ft = 80 liters sealed box, and that it sounds good.
Not surprised.
Put a woofer with these numbers into a sealed 80 liter box, and yu get a Qtc = 1.19.
The range you normally aim for is Qtc = 0.5 to 1.0.
The number of this woofer/box combination, Qtc = 1.19, is only a little bit higher than that, so it still should sound pretty decent.
A sealed box woofer with a Qtc = 1.19 will still have better step response than most vented boxes. And many people, such as myself, like vented boxes.
-Anonymous
Old 9th May 2005, 12:50 PM   #26
Thanks who all replied, for keeping the DIY's spirit up.
Support for the new thread started by me "DIY Loudspeaker construction"
sealed vs. portedHide this!Advertise here!
Sealed vs. ported... and what their relationship to BSC is? fjhuerta Multi-Way 0 30th August 2005 04:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
opinions of T/L box V ported OR sealed busterno1 Multi-Way 13 28th November 2003 08:20 AM
Ported mains / Sealed sub Javaman Multi-Way 3 27th December 2001 09:56 PM
