Old 27th April 2005, 11:22 PM   #1
float is offline float  England
Default SS18w8545/ focal tc120tdx two way
Hi folks, just wondering if anyone else out there has used these drivers to make a two way only system; i.e. not a watt/puppy clone. I have found documented designs on the web, but only for two and a half way or sub/sats like the wilson clones. I have used these units myself in a 16 litre-ish box with second order electrical xovers and am fairly happy with the sound, but would like to hear from any others who feel they might have something good.
Personally, I reckon the scan carbon woofer is a star; it sounds open and dynamic, and has bass beyond its size; the focal tweeter seems to blend well, with a complementary tonality and speed- percussive cymbal hits for example seem more realistic than soft- domes. I guess that I've had these for five years now and I'm still looking to play a bit more, so any and all comments are welcome.
I'm new to these fora, so hello to all; this community has created a truly amazing resource- kudos to each and every one of you.
Thanks in advance
I w isH i cuold typpe bettr
Old 28th April 2005, 06:54 AM   #2
Noksukau's Avatar
I have no experience of the SS woofer but the TC120tdx (mine is tdx2) was my first venture into 'high end' drive units back in Uni. I couldn't get over the energy and detail at the time but now find it a bit tiring. I too am still waiting to see if I can tweak things a little more to get the best out of it, as it's still a quality unit capable of audio magic.
I'm afraid I went with a 3 or 2.5-way design as well, but I'm a little confused as to exactly what help you are asking for, as you seem very happy with the units themselves. Do you just want ideas for new crossover alignments? If you do, and you may well have seen this already, but your speakers are basically identical to the top half of Tony Gee's Andromeda speaker here. He has made a few alterations to the crossover it seems, but is still running it as a 2-way with sub-woofer. Trusting his ears and experience with these units, employed in one of his most impressive designs, I see no reason not to try out his crossover. Then send him a message of thanks for putting a smile on your face!
I've only just arrived on the boards myself (appreciate your classical education btw ), having somehow survived for a decade of building on trial and error and a load of other websites! It was an interest in building a transmission line that led me here and I too am bowled over by the breadth and depth of knowledge, as well as the size and activity of the community. There was me, wondering who all these driver manufacturers were selling their other units to!
Old 28th April 2005, 10:20 AM   #3
BobEllis's Avatar
First off, welcome to diyaudio, float.
Like Noksukau, I have no experience with the Scan woofer and am using the slightly different TC120TD5 in my latest favorite system with a Focal 6w4254. You didn't mention your crossover freq, but I use a 2400 Hz, 4thorder LR active XO.
Looking at the response Tony Gee posted in his andromeda, I suspect that there is some breakup in the Scan cone starting as low as 3KHz. You may find the results cleaner crossing over below that with a higher order filter and/or using a notch filter to tame the breakup modes.
Using a 4th order XO at 2400 Hz my tweeters show no sign of stress at any lisening level that I can stand for more than a few seconds. I had used a second order filter, which seemed a little harsh. I don't know if it was due to overstressing the tweeter, exciting the woofer's breakup modes or both, but it cleared up with a 4th order filter and a notch filter on the woofer.
If you want to get really fussy, you might try a notch filter on the tweeter to tame that small peak in response at around 3-4K. I plan to try it on my next version of the crossover. Not that I hear a need, but the Moxlite boards have eq in the tweeter section so why not?
I am a big fan of active crossovers. Besides being easier to impliment baffle step compensation, EQ and phase compensation, they are less expensive to tweak (meaning I am more likely to keep optimizing) it also gives you an excuse for another project if you need extra amp channels.
Old 28th April 2005, 10:33 AM   #4
Hi Noksukau, and thanks for answering. I read my post again and it is a bit hard to find the question!
Basically, I am looking for alternative crossover schematics, but with full baffle step correction. When I first put these drivers in a box it was with essentially the same values as the andromeda and I was very impressed with the detail, openness,etc. but with the 0.4mH inductor on the midbass there was of course nobass! Adding a woofer underneath is one solution, but I don't really need the volume level so I am happy to trade off sensitivity and stick with a two way.
I am using a 1.8mH on the bassmid to give BSC and a flat response ( although this reduces system sensitivity to around 83dB/watt) and this crosses at about 2300hz to the focal.
As I think I suggested before, I am happy but I'd be very surprised if I can't do better so I was hoping others may have been playing with the same ingredients and wanted to share experience.
I must say the focal "sting" has never bothered me- I cant hear much over 16khz anyway, although my tweets do seem maybe a little hot around 4-5 khz .
Old 28th April 2005, 10:35 AM   #5
I'm using 8545K in my speakers. It is an excellent driver, as you may suppose. Yes, it has some peaks that you may wish to deal with. I'm going to try various serial and some parallel passive filters and will decide which sounds best. Moreover, the driver behaves well in higher volume enclosures, I use it in 22litres with a 29Hz port tune and for now it is the best sounding version, considering the room response.
Old 28th April 2005, 10:39 AM   #6
Yes, I also will use 1.5-1.8mH inductors; now it is 1.5mH and crossover is around the 2500. The HF driver now is a D105 Peerless driver, but it is irritating one so I'll change it sometime
Old 28th April 2005, 10:52 AM   #7
Cheers Bob, your post must have appeared as I was typing my last response. My crossover slopes are about 3rd order acoustic, 2300hz, and seem pretty clean in terms of distortion. It probably helps that the tweeter is padded by around 9db so it never really gets driven that hard.
Active does sound appealing, but at the moment doubling my amp expenditure is not possible. Anyways, I've always thought that if passive is good enough for the likes of wilson and jm lab then its probably good enough for me
How do you rate the focal w-cones against the competition?
All the best
Old 28th April 2005, 11:07 AM   #8
Hi Machinow, the peak on the scan that seems most troublesome is the one around 600-800hz of around 4db or so. I've not tried notching it out because listening slightly off-axis it seems to go away, particularly with a lowish crossover point (it seemed more noticable when I was using a 3.2khz xover). I have wondered if notch filters take away some of the magic
Old 28th April 2005, 11:10 AM   #9
vuki is offline vuki  Croatia
vuki's Avatar
Hi float,
I did a bookshelf 2-way BR with 18w8545 and Revelator 9900 crossover
In my expirience SS8545 cannot be used with simple 2. order crossover because of it's riseing and far reaching response. Using it that way (or even worse with 1. order xover) attenuation slope above xover point is to slow. If one uses larger inductor to overcome this the crossover point gets very low. With your 1,8mH you get very wide overleap with the tweeter and it can make the highs a bit aggressive (even more so with 1,5mH - machinow ).
And, of course, you can't use Andromeda crossover because it's intended for a 3-way so you would have very bright sounding speaker without help of the bass driver.
Old 28th April 2005, 12:04 PM   #10
BobEllis's Avatar
My last few systems have used Focal drivers so I don't have any experience designing with the competition. Before trying the 6W cone, I was using a doped paper 7C for 5-6 years. The W cone trounces the paper, much more detailed and smooth. With the W I hear nuances that were completely obliterated with the paper cone. I noticed a difference between my Leach Amp and my LM4780 amp that I didn't with the older speakers.
The W cone doesn't have the harshness of some of the kevlar and magnesium drivers I have heard in commercial systems when driven hard. Looking at the breakup response of the excel drivers for example, I think the W cone is a lot easier to tame - the peaks are much smaller. I fiddled around with the notch filter, trying with and without. I am not sure that I heard a difference, although it did show up (barely) in measurement. I guess 4th order electrical an octave below the peak may be enough to make a 7 db peak inaudible.
Sounds like you may be hearing that little peak in the tweeter's response. Notch filter time.
The "big guys" have to face commercial realities pushing them to passive XO. If they went active the customer now has to buy an additional high end amp. If the customer then decides to change an amp to one with different gain than the crossover was set for, then the system response changes. Not to mention the "warranty issues" when the customer hooks up the woofer output of the XO to the tweeter amp and cranks up Stanley Clarke.
If they made the levels user adjustable then they subject their reputation to the whims of their not necessarily golden eared customer. When my daughter was at home she'd always crank my subwoofer level all the way up. You'd think my system was pretty lousy, with no top end. Back the sub down to the proper level and it was decent sounding.
True, you need more amplifier channels to go active and that can add up. (this drove my brief foray into chip amps, 4 channels of LM4780 cost about $20 with junk box parts, but it couldn't hold a candle to my Leach so that amp was a giveaway) But, now that I have built more quality amplifier channels than I will likely ever need, I really like the tweakability of an active XO. I can load it with good quality caps for less than the cost of one of some speaker level caps. Shift the crossover point, phase correction or baffle step by changing out a few cents in resistors. Tweaker heaven! Also, for some reason I find the component calculations easier for active filters, but that's just me.
WTB: ONE Focal TC120TDX paul stewart Swap Meet 0 1st May 2009 11:48 PM
Looking For Focal audiom 7k2 or focal 7k6411 jasonyap Multi-Way 0 29th March 2007 06:46 AM
Focal 7 N 401 Mango Multi-Way 1 16th November 2006 09:13 AM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 04:21 PM
Page generated in 0.15183 seconds (74.86% PHP - 25.14% MySQL) with 11 queries
