I'm using a Eminence Legend 875 as midrange in open baffle configuration. Crossover is 160 Hz and 3500 Hz 4th order active L-R. The driver has high efficiency 95 dB and a low mass with 11g because of the paper membrane. The whole thing works quite good with a ribbon tweeter, but needs a lot of digital equalizing. Has anyone a idea for a upgrade for this driver so I need less equalizing? Thanks Stephan |
#2 |
Look for the Audax PR170M0
I never used it personnaly but it has a killler reputation, is affordable and 95 dB in the midrange. There are a few active threads right now about this driver. F |
#3 |
Maybe a PHL midbass driver: PHL 2460
At the moment I am investigating the possibilities of using an 8" midrange for my new system: PHL 2530 But I haven't found any extra data about this midrange driver yet
Tony |
#4 | |
#5 |
diyAudio Chief Moderator
I have experience with the PHL. Its killer.
#6 |
The neo-magnet B&C drivers look very interesting, and aren't even that expensive considering their advanced motor design and B&C's build quality.
#7 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
To me the PHL2460 is a fantastic midrange driver. I use it
in an open baffle up to 2Khz. The FR is flat up to 3Khz. Than it starts to break up. Very detailed and dynamic sound IMHO. |
#9 |
Thank's for the very interesting suggestions. The Audax PR170 seems not so good fpr open baffle use. But the PHL looks quite good. I googled a bit and found the PHL 2520 which seems to be even more interesting. I know nothing about the B&C drivers, has anybody experiences with them or compared them to any other driver? What type you would suggest for midrange use?
With the B200 I'm not sure if it would be a real upgrade but in FR it seems to be a good choice in open baffle. Stephan |
#10 |
I had the PHL 2520 crossed over to a ribbon around 3khz for some time. It's an excellent midrange, detailed and dynamic, yet I feel this unit is better crossed over around 1200-2000hz. It gets a little harsh IMO above 2k. This was probably the designer's intent. It is a pro midrange after all, intended to bridge the gap between a 15" bass unit and 1" compression driver horn.
You will probably need some EQ regardless of what you end up using unless your baffle is wide enough to support the driver down to the crossover point. The Visaton looks most interesting. I would lean toward a full range driver or very wideband midrange with a curvilinear paper cone and smallish voice coil. A fostex FX200 would be great if you can get one. The FE207 might be OK too, or even the FF225K; but overall, i think you'd be better off with a more moderate Q driver. Perhaps the supravox? I don't know how pricey these are in europe. Hope that helps. GB |
| "Best" extended midrange driver below $200 ? | youyoung21147 | Full Range | 48 | 6th May 2011 03:22 PM |
| "Midrange enclosure" articles | claudio | Multi-Way | 6 | 8th August 2010 01:21 PM |
| "Vifa PL11WH09-08 Premium Line Paper cone midrange" | GOWA | Multi-Way | 0 | 17th November 2007 01:22 PM |
| Closed back midrange drivers 4" maybe 3" - recommendations please | RobWells | Multi-Way | 2 | 22nd February 2007 04:59 PM |
| Warm 4" - 5" midrange | Leffemannen | Multi-Way | 6 | 29th March 2006 04:50 PM |
| Page generated in 0.10358 seconds (79.65% PHP - 20.35% MySQL) with 10 queries |
