I have concidered building a closed enclosure version of the Seas Odin speakers. Two Seas Excel w18 and Excel millenium tweeter. The low frequences i lose, i compensate with a ported enclosure for a Seas Excel W26 for each channel. I have two Electrocompaniet AW220 ampifires. I thought about using a passive crossover for the midbass and tweeter, and a Hypex DS 2.0 for each Excel W26 element. Would you think this could play well?
#2 |
I cant see anything wrong with this. If you keep the baffle width pretty much the same as the odin and thor you can just use that xover.
Just put the W18's in an enclosure to give you a Q your happy with, Id suggest 0.5-0.7. I am assuming you are going to use an active xover to blend the W26 with the W18's as a sub?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
I thougt of having about the same baffle width and hight as the odin, changing the depth of the cabinet. Its recommended to have 8 L for each W18 element, so a cabinet on 15-17 L for the midbass.
IŽd like the sound to have tight bass response, so a Q factor on 0,5-0,6 would be preferable. Though i am not any expert for calculating Q-factors... IŽll try using the odin/thor xrossover. The sealed cabinets will give a higher f3, so iŽll probably dont need a high-pass filter for the midbass..? For the W26 iŽll use an DS 2.0 amp. It has an active lowpass xover, so i dont think blending the sub will be a problem... its recommended to have 120 L ported cabinet for the W26. Thought of using the sub cabinets as stands for the midbass cabinets. |
| Q in closed box design | Hyldal | Multi-Way | 23 | 18th July 2007 11:05 AM |
| Closed sub box | Tenson | Subwoofers | 12 | 27th June 2006 05:53 PM |
| linkwitz transform equalised sub + closed seas excel speakers | deiksac | Multi-Way | 5 | 31st October 2005 11:36 AM |
| XO for closed box with some eq... | ktkammon | Multi-Way | 0 | 28th June 2004 02:56 PM |
| Page generated in 0.07853 seconds (69.21% PHP - 30.79% MySQL) with 10 queries |
