Old 27th April 2005, 03:55 AM   #1
Madmike2's Avatar
Default A padawan needs guidance here
HI again. I just had another idea. Feel free to rip this apart. Keep in mind that i will have active EQ and 6 channels of amplification. Ok what i propose is and correct anything i say wrong i can go back and read all the data again till i understand it exquisitly. here is a cheesy picture to clarify my written description.
http://i4.photobucket.com/albums/y12...ike2/Basic.jpg
i want to take Surgical packing foam, it comes in a grayish black colour and flat sheets of 5/8's thick and sandwich it. Front baffle will be 1/2 inch white pine and the rear support and baffle will be 1 inch mdf that i have. each panel will be 4 x 8 inch woofers wired series paralell to a single channel. In the middle of these sitting side by side will be a 4 inch mid and cd5 fountek ribbon tweeter either wired together to one channel with a simple 12 db crossover since there will be an active x-over removing 400 Hz and lower. Or i can run the tweet on a channel the mid on a channel and the 4 x 8 array on the 100 watt channel with the Dbx doing crossover duty. The front baffle will be in the range of 90 % decoupled from rear as i will use 2.5 inch black mushroom bolts and polyurethane donuts on the back side with wingnuts to cinch the speakers to the front baffle. Almost all the transmission of energy that does make it to the back will be through the poly as the medical foam is CDC certified for vibration absorbtion.
So from what i understood part of the problem with an open baffle IS the baffle. Will taking its effects out or shrinking its footprint in the reproduction picture help ?
Just so you know i just backspaced a whole freaking book back to here, just to ask it in a way i SHOULD have asked it. WIll this design affect or lesson the baffle effect in this design assuming that this array would be valid? Or will it just destroy the point of the open baffle.
I will be reading SL page while i wait for the flaming to begin :-)
Michael
Old 27th April 2005, 02:34 PM   #2
Madmike2's Avatar
Ill take the lack of response as a good thing. Are you all trying to figure out if it would actually make a difference?
In that picture the red fill between the black and the blue is supposed to be the foam sandwich.
Old 27th April 2005, 04:29 PM   #3
Speakerholic
Cal Weldon's Avatar
Can't answer anything about the OB but you might wish to vertically align the mid and tweeter.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 27th April 2005, 07:36 PM   #4
Madmike2's Avatar
Really ? i didnt think that would make a diff with such a gigantic baffle area.
Old 27th April 2005, 07:38 PM   #5
Madmike2's Avatar
Darn, putting those vertical adds 7 inches in height. Thats not a good thing.
Old 27th April 2005, 09:07 PM   #6
adason is offline adason  United States
adason's Avatar
how about this arrangement /use any amount of woofers, i just did not wanted to redraw whole pic/
that should reduce the hight considerably
Old 27th April 2005, 10:46 PM   #7
Madmike2's Avatar
I see . Stick to the line pattern. So in essence i coult MtM a line in the middle of the woofers ? Or as in your picture edit i could off set them as if it was a ribbon line along side.
Old 28th April 2005, 04:26 AM   #8
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
well in the above situation there will be some source shifting continually due to different horizontal positions,how bad,I duno.
Id go vertical if possible. Why 4 x 8"s?Wont 2 do?
Bear in mind that the 8"s if reproducing the same frequency range will comb filter when the wavelength approaches the driver to driver spacing[midrange]
Old 30th April 2005, 05:06 AM   #9
frugal-phile(tm)
planet10's Avatar
What drivers?
Nothing wrong with the design. MJKs Focal TLs worked better with side-by-side driver mounting -- showing that conventional wisdom always has to be considered with a grain of salt.
The wider the baffle the lower the bass.... as drawn you will need lots of EQ to get any bass, and 4 8s probably will run out of excursion... making the baffle wider means you won't have to work them as hard.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th April 2005, 05:52 AM   #10
Madmike2's Avatar
Hi Dave, i just talked to you in the other forum Man i am a little tipsy right now on a brilliant california red.
The current dilemma floating in my head purculating its math around is a series of SIX 6.5 inch Vifa's LCY tweeter 6 inches north of center on a 19.5 in wide baffle 54 inches tall.
I have EQ and multi amps covered to play with i am just trying to imagine the sound. Its a lot of money for me. I am the cheapest guy around unless it involves something that entertains me
Looking For Some Guidance CARTRulz Subwoofers 11 15th May 2006 07:34 AM
Looking for Guidance - OLD parts - VCA's pwillard Analog Line Level 3 18th February 2006 08:38 PM
little guidance thermonuclear Full Range 4 1st September 2005 11:49 AM
Some Guidance thermonuclear Chip Amps 8 27th August 2005 05:05 PM
Newbie Guidance... Paprika Solid State 22 13th February 2004 07:16 PM
Page generated in 0.11912 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
