What wire use for xover
Old 25th April 2005, 08:08 PM   #11
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hi Chris,
You may find quite a range of answers on this one but to look at it from a reasonable side of things, you will find things far more important inside your boxes than the wiries going to and from your XO.
Originally posted by DIY_newbie
Also, I used gold plated quick disconnects on the midranges and gold plated ring terminals on the tweeters. Should I have just soldered to the actual speaker drivers?
I use aluminum slide on connectors and depress the retainer tab inside so the wire can slide right up to where the connector part slides over the spade. This aluminum connector holds it in place nicely while I solder the wire directly to the spade. I use aluminum so the solder joint is between the wire and the spade as solder doesn't stick to aluminum and you can be sure of a positive connection. In my eyes, a good solder joint is more important that what kind of wire you use.
But that doesn't stop other from having widely varying opinions on this. As mentioned earlier, I try and be as reasonable as possible when considering what materials to use, where and how.
Beware of snake oil, there is much to seen in this hobby.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 25th April 2005, 08:25 PM   #12
I second the cat 5 utp as speaker wire.
8 cores of insulated 24g in each cable. You can bundle as many as you like after stripping off the outer sheath. 40 ($75) per 1000 feet is cheap. Sound nice and clear & 24 core makes good bass cable @ my length of 700mm. 8core to treble and 16 core to mid.
I have not experimented with the clever braiding suggested on some web sites.
regards Andrew T.
What wire use for xoverHide this!Advertise here!
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
inductor wire gauge for line level xover? poldus Parts 0 2nd October 2007 04:06 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Copyright ©1999-2017 diyAudio
