Old 14th November 2005, 06:32 PM   #101
wrl is offline wrl  United States
Wow, marble speakers would be crazy heavy, especially ones the size of mine
-Wes
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was.
Old 15th November 2005, 11:57 AM   #102
Artmaster's Avatar
Send a message via ICQ to Artmaster Send a message via MSN to Artmaster
gday!
first hand - it's no a problem realy. do you want to transport it often? I'm not sure.
second - anyway you have to use very strong material, or thick wood, or veneer for nice box damping. and your box will be heavy as well. isn't it?
should you will make it yourself - you want to get maximum quality, so it's not easy way.
Artmaster live in www.artmaydan.org.ua
Old 21st November 2005, 06:38 PM   #103
Mark,
How is the shop setup progressing?
-Wes
Old 29th November 2005, 07:11 PM   #104
mwmkravchenko's Avatar
Default Shop Progress
I have power a running table saw and jointer/planer. THe shaper is ready to move in to. Should be fully functional by the end of the month. Right now I'm working on heat. Got a big wood stove and am preparing the chimeny.
Mark
Mark
Old 30th January 2006, 06:41 PM   #105
OK, back from a long delay (finishing school) I finally have time to finish these darn things.
I was doing some more experimentation with the veneer/practice blanks and I really like the look of just spraying on some dye and then sealing with shellac then lacquer. The wood has a little bit of irradescence that makes it look really nice.
My question now is how to get rid of the wood grain texture in my final surface. I know that pore filling is how this is usually done, and I would simply use plaster of paris, but this seems to eliminate the irradescene of the veneer. Can I fill with multiple coats of lacquer and then sand back? Or do I need to get something like polyurethane?
Any other suggestions?
Thanks,
Wes
Old 31st January 2006, 12:17 AM   #106
Talking YEah BAby!
Yes you can!
You need thre or more coats before you start sanding. Use a block and soapy water as a lubricant. Sand it down with 320 until it looks decent and then coat with a couple more layers of laquer. Then sand it down. It is a good idea to coat the layers within a hour or less. Let it dry thoroughly for at least a day or two. THen sand them and give them the subsequent coats. Let it dry again for atlest a couple of days. Then sand it well. Give it a beauty coat. Let that set up a couple of weeks and then if you want the whole nine yards you sand it with 1000 lubricated at all times with the water and soap. And then buff it with automotive cream buffing compound. Yes it can be done by hand. Will look like a million bucks.
Bottom line think this way. A good coat of laquer wet is about 0.012" If you have thinned it correctly and taking into consideration the actual solids content you may build up a layer of around 0.005". Not much!
When I was doing some board room tables the first time I did what you want to. It took 36 coats of laquer to get that glass smooth surface. I since have cut that down to less than 12. Practice makes perfect!
MArk
Mark
Old 31st January 2006, 06:33 AM   #107
36 coats!!! Oh man, these things are 5 feet tall! I better buy some more pints of lacquer... or maybe a case.
I cracked and bought a small air compressor and I am planning on buying a spray gun next weekend. It won't run an HVLP system, but I figure it should be better than trying to brush on coats. I think its about $75 from home depot.
A quick question about where the veneer edges meet. I know there was some previous discussion about pounding/malleting/killing cats, but I was still unclear as to how this method works. I have angles that are only 30 degrees along one side and I like to keep them relatively sharp so bending a single sheet isn't an option. but fortunately the angles should make edge matching unnecessary. I'll post pics soon to hopefully make is more clear.
Thanks so much for all your help so far. I know that many of my projects and possibly my interest in speakers in general might have crashed long ago if not for this site.
-Wes
Old 1st February 2006, 07:33 AM   #108
Illusus is offline Illusus  Canada
Illusus's Avatar
... if not for this site
Amen.
30deg...when I have such angle I build a jig to hold a razor blade at a corresponding angle to cut the venner with...but bashing some butt joints together works damn well too(I think I mentioned it a month or two ago). I'm a little confused though...30deg is pretty acute, are you sure it's not sixty( it all depends on how you look at it). Got a drawing/plan?
Mark's block sanding suggestion is spot on... personally, I like to use a balsa wood block(nice and true) and let it's own weight do the work...smooth as a baby's bum.
Edit...What's wrong with butt? can't say butt 'round here without getting a hassle?
Fighting the program since 1976.
Old 2nd February 2006, 08:23 AM   #109
dc270 is offline dc270  United States
Default Wood Link
Very nice look, and you'll pay dearly for it too!
I have used the folks before, might get some ideas here;
http://www.woodnshop.com/Hardwood/Walnut_Veneer.htm
Good luck
DC
youi can't do that...why it's heresey....or so they said to Paul Klipsch!
Old 2nd February 2006, 09:49 AM   #110
el`Ol is offline el`Ol  Germany
There is a method to transfer the surface of sandstone to textile, which can result in similar patterns, depending on the stone.
something to finish mdf paulfk Multi-Way 14 14th March 2009 03:04 PM
Help! Finish gone bad ShinOBIWAN Multi-Way 13 7th July 2006 11:54 AM
MDF Finish bjackson Multi-Way 26 4th June 2005 12:41 AM
Enamel finish bjackson Multi-Way 11 26th April 2005 08:40 PM
Wood finish fireman Multi-Way 15 25th October 2004 08:06 PM
Page generated in 0.24427 seconds (93.13% PHP - 6.87% MySQL) with 11 queries
