I have a KEF Ref 105.3 that is making a warbling / burbling type of noise. The other speaker is fine.
It appeared to be coming from the top driver. I took this out, and tested it on its own, and it seems to be fine. On putting everything together again, the noise returned. It appeared that it could be coming from the central coincident drivers - I didn't get time to test this out of the cabinet. There are two potential causes. 1. RF interference: this speaker sits between a Pronto and its RF receiver, and next to an equipment cabinet (it is permanently wired in, and difficult to move to another location for test). This doesn't seem likely - to be audible, RF would need to be amplified; to get back to the amp through the crossover, it would need to be noise on OV, which presumably would then pervade the other channel. 2. A dodgy cap in the crossover (no visible sign of problems with the crossover). There is no scratching, and the cones push in freely, so I don't think there is any voice coil damage (though obviously I can't tell with the tweeter). The speakers have never been used at a particularly high level (and have worked fine until recently). Can anyone give me a steer for my next fault-finding session? Thanks |
#2 |
Have you swapped amp channels to the speakers to see if the problem moves? To be honest, this sounds much more like an amp problem than a speaker one.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Hmmm. I was sure that I tested this. Turns out that it's the PL2 mode of the Denon AVR3805 receiver. Sorry for the trouble.
Have you done anything with those B139's yet? |
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| SI Super-T and speaker AB switch to ONE speaker | Taperwood | Class D | 25 | 24th March 2006 02:08 AM |
| Some Speaker Completed Speaker Projects | dc270 | Multi-Way | 1 | 19th February 2006 01:33 AM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Page generated in 0.06916 seconds (75.42% PHP - 24.58% MySQL) with 10 queries |
