Old 19th April 2005, 11:38 AM   #1
graks is offline graks  Norway
Send a message via MSN to graks
Default Tweeter damping?
I have a pair of Seas Thor speakers, i think the tweeters are too bright/loud. Any suggestions on how to modify the crossovers? Http://www.seas.no/thor
Old 28th May 2005, 06:26 AM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
link not working. perhaps a L-pad for the tweeter?
Old 28th May 2005, 02:11 PM   #3
Paul W is offline Paul W  United States
Paul W's Avatar
Another thing you might try is a parallel LR circuit inserted in series with one of the lines between the amp and speaker. This will "tilt" overall system response and help preserve the relationships within what is probably a very well designed crossover.
You can determine starting values with simulation software. If you don't have software, start with a low value, low DCR, air core inductor paralleled by a low value high quality resistor. Higher values of L will start the tilt lower in frequency, higher values of R will increase treble attenuation...so you can adjust the values to get the result you want. Just insert the parallel LR combo in one of the lines running to the speaker.
Old 28th May 2005, 03:01 PM   #4
Vigier is offline Vigier  Netherlands
there's a 2,2 Ohm resistor directly in series with your tweeter.
For 1 db lower SPL replace it with a 3.3 Ohm and for a 2 db lower SPL replace it with a 4.7 Ohm resistor.
Make sure you use at least a Metal-Oxid (MOX) resistor, definitely NOT a wire-wound.
Grtz, Joris
Old 28th May 2005, 03:13 PM   #5
RJ is offline RJ  United States
I think what Paul W is trying to explain is baffle step correction.
Try .1 mh inductor in parallel with a 4 ohm resistor.
Old 28th May 2005, 06:40 PM   #6
Paul W's Avatar
RJ...Same circuit as baffle step compensation but broader range, more subtle, and acting on the full system rather than just the woofers (to avoid munging relative phase response within Thors crossover...which is probably good without modification). I am guessing around .2 mh and 1 ohm or so...but you could be right, my values are just a guess without sims.
Tweeter damping resistor. Why? zebra100 Multi-Way 13 24th May 2009 11:39 AM
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 03:41 AM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 06:52 PM
TL damping kro5998 Multi-Way 1 19th January 2007 05:43 AM
BH 5 damping kyrill Multi-Way 11 22nd June 2004 06:28 AM
Page generated in 0.09460 seconds (76.68% PHP - 23.32% MySQL) with 10 queries
