Old 19th April 2005, 03:46 AM   #1
Speakerholic
Cal Weldon's Avatar
Default Capacitor question
Brain cramp.
I have an 8 ohm tweeter that I crossed over at 12K, 6 dB with a 1.5 mfd cap. It was a little strong so I added a 4ohm resistor to it. The output is fine but now there is an overlap with the mid. What do I have to add to it to get back to the 12K XO point? I'm thinking it's around 9K right now.
Thanks for the help ahead of time,
Cal
Edit: I don't have any 1.1 mfd here right now or this would be easy. I have lots of other assorted so I would like to add to it rather than replace.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th April 2005, 04:45 AM   #2
RAW is offline RAW  Canada
Cal
Shoot me the complete filter.I can crunch something before you come.
MLSSA is waiting.
Will have praxis to show you as well.
Al
Old 19th April 2005, 05:01 AM   #3
Speakerholic
Cal Weldon's Avatar
Thanks Al,
I actually played around a bit and got it a little better. I'm thinking it's about as ready as it going to be for the test. I'm really enjoying having your LCR units here tonight. It was a real eye opener to hear yours vs mine. Are those gonig to be for sale one day?
Cal
Old 19th April 2005, 05:06 AM   #4
NO no not LCR
LCR uses the 2 Extremis the CSS125 as a mid and a usher tweeter.
You have the RA241 for now.
Al
Old 19th April 2005, 05:19 AM   #5
Speakerholic
Cal Weldon's Avatar
Oops,
Sorry old boy, didn't know they had a number. I'll stamp that one on my heart Anyway I sure do appreciate the use of them. Now I can see what happens when you spend the time to do it right.
How 'bout we have a duel tomorrow, 7pm, your place, ten paces, turn and fire your remote at the amp and we'll see who comes out on top. Mind you, mines bigger.
Cal
Old 19th April 2005, 05:40 AM   #6
quasi is offline quasi  Australia
quasi's Avatar
Default Re: Capacitor question
Originally posted by Cal Weldon
Brain cramp.
I have an 8 ohm tweeter that I crossed over at 12K, 6 dB with a 1.5 mfd cap. It was a little strong so I added a 4 ohm resistor to it. The output is fine but now there is an overlap with the mid. What do I have to add to it to get back to the 12K XO point? I'm thinking it's around 9K right now.
Cal
By inserting the 4 ohm resistor on its own you changed the tweeters effective impedance to 12 ohms and this has changed the timing cct of the capacitor hence shifting the crossover point.
To fix this you need to add a 2.2 resistor in series after the 1.5 uF capacitor and an 18 ohm in parallel with the tweeter. This will bring the tweeter level down by about 3dB and maintain 8 ohms for the crossover capacitor.
Cheers
Old 19th April 2005, 05:56 AM   #7
Speakerholic
Cal Weldon's Avatar
Hi quasi,
Thanks a lot for your response.
I did what I could with what I had on hand for now. I added an 8.2 across after the 4.2 in line, dropping the dB's heavy and basically bringing my XO back to the separation I had before and it actually sounds OK. The tweeter is quite efficient so no big deal.
Man, I am such a hack. I'll have another go atter tomorrow before I head over to RAW
I'm going to bed.
Cal
Old 19th April 2005, 06:03 AM   #8
frugal-phile(tm)
planet10's Avatar
Cal,
the easy answer is to change the cap to 1 uF to get back the same nominal XO frequency (13,300 Hz). Nothing else required. If needed i'll teleport one over
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th April 2005, 06:08 AM   #9
quasi's Avatar
Originally posted by planet10
Cal,
dave
Hi Cal,
If he does that he will shift the crossover frequency back, but the level will be the same. I read that he wanted to bring the level down because it was too strong. Adding two resistors is still pretty easy.
Cheers
Old 19th April 2005, 07:04 AM   #10
frugal-phile(tm)
planet10's Avatar
No it won't, the level will come down, with ~ 2/3 the voltage across the driver there was before.
an L-pad is more appropriate with a more complex XO or when you want to be able to dynamically change the level, but this is better when it is a simple cap XO.
dave
PSU Capacitor question Cloth Ears Chip Amps 11 17th January 2010 11:56 AM
Capacitor Question... SigloOne Tubes / Valves 15 3rd May 2009 06:39 PM
Capacitor question... Again and again... Dxvideo Chip Amps 14 9th January 2008 08:27 AM
capacitor question crippledchicken Solid State 3 31st October 2007 09:12 PM
Capacitor Question audiodumb Car Audio 15 22nd June 2005 03:49 PM
Page generated in 0.11703 seconds (79.34% PHP - 20.66% MySQL) with 10 queries
