Old 17th April 2005, 10:58 PM   #1
David Gatti's Avatar
Default Ferrofluid & power handling
Does anybody have any data on how much greater power handling a ferrofluid cooled tweeter has relative to a non-ferrofluid one?
www.gattiweb.com
Old 17th April 2005, 11:23 PM   #2
5th element's Avatar
Well not exactly a true % but maybe more informative then im thinking. Seas tweeters now come (well a few models do) with and without ferro, these tweeters looks pretty much exactly the same appart from the ferro.
The non ferro unit will handle 55watts and the ferro one 90.
But in the excel line up the non ferro excel tweeter handles just the same power as the one with ferro.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 17th April 2005, 11:41 PM   #3
So it seems that in some cases power handling isn't really the main benefit of ferrofluid, i.e. it's used mainly to damp resonances?
Old 17th April 2005, 11:53 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
For a datasheet comparison, maybe look at the Peerless 811815 (non-ferro) compared to the 811827 (ferro). As far as I know those drivers are exactly the same besides the ferro fluid.
On the 811827 page: "The magnetic oil in the airgap adds viscous damping to the system and increases the power handling".
The power of Science compels you!
Old 18th April 2005, 12:12 AM   #5
Those Peerless graphs show 100W non-ferrfluid vs 130W ferrofluid. Hardly significant I would have thought.
It's interesting that most of the top end tweeters make a point of having no ferrofluid for "enhanced micro-linearity".
Old 18th April 2005, 12:29 AM   #6
soongsc is offline soongsc  Taiwan
soongsc's Avatar
This is quite interesting to think about. One would think having fluild to use friction to dampen a coil movement would create some "sound" that will have adverse quality unless you normally play them loud enough that it doesn't matter. For low level listening, probably the non-ferro ones would be better?
Hear the real thing!
Old 18th April 2005, 01:01 AM   #7
I was also wondering if ferrofluid can break down or change it's properties after a 5-10 years.
Old 18th April 2005, 02:18 AM   #8
DcibeL's Avatar
That's what I have been told. I've never been able to do a side by side comparison of a ferrofluid and non-ferrofluid version of the same driver to be able to judge for myself though.
Old 18th April 2005, 03:02 AM   #9
frugal-phile(tm)
planet10's Avatar
Without FF you often end up with a tweeter that is much harder to XO, so you may have trouble accessing the extra detail (claimed) available with a T without.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
power handling lsutherlin Multi-Way 1 19th October 2007 10:57 PM
Power output vs speaker power handling Bob0513 Chip Amps 4 5th November 2006 10:41 AM
Crossover/Power Handling Mutley666 Multi-Way 0 9th March 2005 09:55 AM
TL Power handling fortyquid Multi-Way 9 13th October 2003 12:18 AM
Power Handling Myren Multi-Way 1 30th October 2001 07:18 AM
Page generated in 0.25468 seconds (31.64% PHP - 68.36% MySQL) with 10 queries
