I have a pair of MW 267. These are Morel speakers. Their specifications are as follows:
frequency response 25-3000 Hz resonance frequency (fs) 25 Hz effective piston area (S) 219 cm squared equivalent gas air load (VAS) 113 liters moving mass (MMs) 24 gm total Q. factor (Q/T) 0.33 electrical Q. factor (QES) 0.4 mechanical Q. factor (QMS) 2.08 suspension compliance (CMS) 1680 uM/newton if I'm missing any information needed to calculate the appropriate closed box volume please inform me. You can find the rest of the information at the Morel web site. www.morel.co.il/drivers/woofers/mw/frameset.htm as this is my first speaker I don't want to make a reckless mistake. Can someone tell me what the optimal volume from my enclosure is? My calculations came out to around 22 L. my enclosure is a closed enclosure. Thanks for all the help. Eitan Waks |
#2 |
Did it Himself
You have supplied enough T/S parameters, but one mans optimal is another mans trash can. What kind of sound are you looking for? How close to walls will the speakers live?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
frugal-phile(tm)
My sw generates boxes between 17.5 litres (0.9 Qt) and 87 litres (0.5 Q) -- a Q of 0.707 needs a 31.5 litre box.
It is hard to make a sealed box the "wrong" size. as long as it isn't too, too small (and if that is the case you can make it aperiodic) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
Davy Jones |
#5 | |
frugal-phile(tm)
If you've ever heard a set of properly set up Linn Isobariks you know sealed can produce bass. In this case bass is probably more limited by excursion capabilities. dave
#6 |
Richie00Boy,
the speakers will be quite close to the wall due two architectural limitations. By quite close I mean around 50-100 cm. Maybe even closer. As to the type of sound that I am aiming for, I am not quite sure because this is my first project. I enjoy a full sound is, nothing to tight. However, I also like a very dynamic speaker. I listen to a wide-ranging of musical genres, anything from opera and classic to rap and rock. Dave Jones, I am not currently planning and using a subwoofer. In the beginning I was opting to use a 6 in. driver however, I decided on not using a subwoofer therefore a move to an 8 in. driver. Thank you everyone for all replies. This form is proven to be very helpful. I attach the plans for my speaker. I would really love some critique. What your thoughts? Total height: 425 mm total width: 327 mm total depth: 438 mm |
#7 |
Did it Himself
That's a very nice design. 22 litres will give you a peak before roll-off and slightly higher -3dB point. I would say that your speakers are fairly close to walls at 0.5m and so they will gain a small amount of reinforcement. I'm not sure that your box is big enough but won't be able to check until I get home.
Can you consider a vented box? You will get quite a bit deeper output that way.
#8 | |
frugal-phile(tm)
dave
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Box Volume is Box Volume, right? | skooter | Car Audio | 5 | 4th November 2008 05:17 AM |
| set volume with 50k Pot on Zen V4 | cHab | Pass Labs | 2 | 17th June 2008 12:49 PM |
| volume pot | william1981 | Solid State | 5 | 25th February 2007 10:31 PM |
| sub volume help | jpark | Car Audio | 0 | 3rd April 2006 09:16 AM |
| Page generated in 0.11189 seconds (79.51% PHP - 20.49% MySQL) with 11 queries |
