Old 16th April 2005, 03:37 PM   #1
bser is offline bser  United States
Default multiple room system on the cheap
Hey guys taking a stab at doing a multiple room install for my parents, but they don't want to spend too much. My moms first thought of course was why don't we get a bose system
"Nah ma, I'll come up with something." So basically what I"m looking for is something to "one up" bose as far as sound quality goes. I don't have a specific budget yet, but in the ball park of $500 dollars for drivers and an amp would be nice if this is at all possible. With this kind of a budget full range speakers with no x-over is a must I'd assume. Probably going to be looking at somewhere around 16 drivers needed. Nothing extremely elaborate, and I realize that low bass extension will be nonexistent. Also the enclosures have to be on the small side, I"m thinking of mounting them in the ceiling corners of each room. 2 per room. I'm looking for drivers first of all, then I'll go about searching for an amp, or use one that I already have. I'm assuming with 16 speakers it won't be hard to get the correct ohm load for an amp. Anyone with experience doing this sort of install please comment with suggestions. Thanks guys.
Old 16th April 2005, 06:26 PM   #2
EDIT: only 8 drivers needed, only doing the public areas of the house ( no bedrooms, bathrooms etc)
Old 17th April 2005, 12:06 AM   #3
Speakerholic
Cal Weldon's Avatar
I'd start by looking through the PE website and coming back with questions after narrowing down some of your choices. Full range is a good way to save your bucks and there are some good drivers out there.
Are you going to build boxes or maybe put the drivers in the walls?
Cal
http://www.partsexpress.com/
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 17th April 2005, 05:42 AM   #4
I'm thinking boxes
Old 17th April 2005, 05:50 AM   #5
the first name that comes to mind is fostex, I've heard many great things about their full range drivers on this forum. Is there a specific driver from fostex that is prefered above others?
Old 17th April 2005, 06:26 AM   #6
frugal-phile(tm)
planet10's Avatar
Default Re: multiple room system on the cheap
Have a look at this thread -- we are talking about just such a speaker...
Super baltic birch
The Aura at the top of our list would set you back $156 for drivers, leaving room for amp(s) boxes etc.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th April 2005, 05:28 PM   #7
thanks planet much appreciated
Old 17th April 2005, 05:50 PM   #8
was it the 4 inch speaker from aura you guys were looking at or the 3 inch? The 3 inch looks very impressive. I'm not sure the 4 inch will extend as high as I would like it to. I'm also concerned with the low effeciency of the speakers. Would a pair of them be enough to fill a larger room (say 18x30) with at least a listenable level of music?
Old 17th April 2005, 05:56 PM   #9
was this the speaker you were looking at?
NS3-194-8E
that does indeed look very impressive. Have you had a chance to listen to them in a small sealed enclosure? At that price I may be able to do 4 per room instead of the 2 I was origanally intending to do.
Old 17th April 2005, 06:22 PM   #10
frugal-phile(tm)
planet10's Avatar
Originally posted by bser
[B]was it the 4 inch speaker from aura you guys were looking at or the 3 inch? The 3 inch looks very impressive. I'm not sure the 4 inch will extend as high as I would like it to. I'm also concerned with the low effeciency of the speakers. Would a pair of them be enough to fill a larger room (say 18x30) with at least a listenable level of music?
the 3" unit... there is no getting around low efficiency in a small speaker if it is going to have any bass....
dave
The Advantages of Floor Coupled Up-Firing Speakers graaf Multi-Way 2545 Today 06:02 PM
Multiple Sub/Dipole/horns for small room? THE_COW_IS_OK Subwoofers 12 27th February 2009 05:26 PM
Alternatives to squeeze box for multiple room setup ceebmoj Digital Source 0 28th February 2008 01:09 PM
cheap room anyliser Pbassred Multi-Way 0 29th November 2004 06:51 PM
System Efficiency when using multiple drivers AudioFreak Multi-Way 14 2nd December 2001 05:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
