#11 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
do you suppose with the greater excursion and power handling that the 193 will be able to put out more sound across the whole range than the 194, or will the low sensitivity prohibit that? It won't need to play loud but the rooms it will be filling will be large, and it need to be at least audible
#13 | |
frugal-phile(tm)
the 193 becomes excursion limited at about 125 Hz, i expect the 194 wouldn't give much below 200. And these have some of the best bottom of the lot. dave
#14 |
well thanks for your help man, looks like I'll be ordering some 193's and checking them out, let ya know what I think. Has there already been a project done with a sealed box that perhaps you can refer me to? Thanks again
#15 | |
frugal-phile(tm)
dave
| The Advantages of Floor Coupled Up-Firing Speakers | graaf | Multi-Way | 2542 | Today 09:25 AM |
| Multiple Sub/Dipole/horns for small room? | THE_COW_IS_OK | Subwoofers | 12 | 27th February 2009 05:26 PM |
| Alternatives to squeeze box for multiple room setup | ceebmoj | Digital Source | 0 | 28th February 2008 01:09 PM |
| cheap room anyliser | Pbassred | Multi-Way | 0 | 29th November 2004 06:51 PM |
| System Efficiency when using multiple drivers | AudioFreak | Multi-Way | 14 | 2nd December 2001 05:44 PM |
