8" woofer with 4" VC
Old 19th April 2005, 05:20 PM   #11
meil is offline meil  Denmark
They have this order form. And it is possible to design your own driver and they cost almost the same at the standard driver.
I know of one using at 7 Flexunit with a 4 coil.
See pic.
Old 19th April 2005, 06:28 PM   #12
AJinFLA is offline AJinFLA  United States
Banned
Default Thanks Meil
Now that's interesting! I will investigate further. BTW see what pic?
AJ
Old 19th April 2005, 08:32 PM   #13
I have problems with attachment
Try this instead
http://home25.inet.tele.dk/meil/at.jpg
http://home25.inet.tele.dk/meil/flex_6.jpg
The number of those two are Flex Unit
6 D 102 10 20 SD and
6 A 77 10 20 SD
Only the small one are mine.
Old 19th April 2005, 09:34 PM   #14
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Try this instead
6 A 77 10 20 SD
Hi meil!
Do you know how these elements sound?
Are there any spcifications on these, frequency response or so??
Regards Michael
Old 19th April 2005, 10:24 PM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Probably best thot of as upscale Dynaaudios or Scan-Speaks (since the fouder started both those companies)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th April 2005, 12:47 AM   #16
Banned
Umm, Dave, I caught the last part of your quote - about the founder of AudioTech being the founder of Dynaudio and Scan, I knew that one, but what was the first part??
its never too early
AJ
Old 20th April 2005, 12:59 AM   #17
frugal-phile(tm)
planet10's Avatar
Never did learn to type (took Grade 11 math instead of Grade 10 typing)
Also of note, is that much of the tech in these inspired Nick to create his outstanding Llambda drivers.
dave
PS I edited the post to make it a bit easier to grok...
Old 20th April 2005, 01:34 AM   #18
Banned
Gotcha! I type as fast as paint drying myself. Upscale Dynaudio - oh my! Perhaps I'll stick with the Hi-Vi to experiment (the're not exactly giving those away at $90 US ea.), then take the hammer to the piggybank for the Audiotech Flex units upon final design. They do look tasty.
Thank you sooo much guys, this board is a godsend
I'll run with the ideas given here. I'll try to post updates when possible. This project will take a while (like all my others), but hopefully will be complete before the sun turns red.
AJ
Old 20th April 2005, 01:54 AM   #19
frugal-phile(tm)
planet10's Avatar
You can probably get a dozen HiVis for the price of a pr of ATs
dave
Old 20th April 2005, 06:28 AM   #20
Correct, they are not cheap, but when your receive and listen to them, then you understand.
http://home25.inet.tele.dk/meil/meil05.jpg
8" woofer with 4" VCHide this!Advertise here!
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 10:50 PM
von schweikert unifield 3, an offshoot from "fullranger with helper woofer" d to the g Multi-Way 15 24th September 2008 10:34 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
