Soundeasy Open Baffle Question Soundeasy Open Baffle Question - diyAudio
Old 16th April 2005, 01:06 AM   #1
DougL is offline DougL  United States
Default Soundeasy Open Baffle Question
I downloaded the Soundeasy 10 Manual, and found the U and H baffle support. Does it also support "flat" open baffles?
I know if I made the wings very small on a U baffle it would probably work. I was just looking for confirmation before I purchased it.
I have an open baffle project in the works, and was hoping I could use the software to save a lot of MDF trees.
Comments welcome.
Doug
Old 20th April 2005, 04:11 AM   #2
Thanks for the Views.
Hopefully, someone that knows will happen by.
Old 20th April 2005, 12:38 PM   #3
rick57 is offline rick57
Not sure if Iím someone that really really knows, but Iím pretty it only does U and H baffles (check with SE or John K).
For flat baffles, Iíd use SLís formulas.
Hope this helps
Soundeasy Open Baffle QuestionHide this!Advertise here!
sub amp question for MJK open baffle pforeman Full Range 7 15th May 2009 07:19 PM
A MTMvTMM? & A Open Baffle Question Ben Reginato Multi-Way 1 18th October 2006 12:06 PM
Open-baffle design question Aengus Multi-Way 6 17th May 2006 06:37 PM
Open Baffle vs Box Speaker Question Robert McLean Full Range 23 24th May 2005 09:54 PM
Electrostatic HF, Open Baffle LF Question mrfeedback Multi-Way 1 21st August 2002 02:40 AM
Copyright ©1999-2017 diyAudio
