Old 15th April 2005, 08:25 PM   #1
Default Need help with design
Hi, I know this is not a Scan-Speak, but is the best affordable and available driver i can get here. The main idea is to use in a 3-way enclosure, with a dipole mid-driver, but don't know for sure if i should port or not the bass. Is an hybrid box, like the Acapella SE.
Here's the driver data:
Audifiel 10BX (www.audifiel.com)
Z = 8 Ohm
Re = 5,5 Ohm
Fr = 46 Hz
Qa = 4,2
Qe = 0,7
Qt = 0,6
Mms = 0,034371 Kg
Cms = 3,48E-4 Nw/m
Bl = 8,84 Wb/m
Sd = 0,035968 m2
Vas = 6,31E-2 m3
Rms = 2,37 Kg/s
P max = 200 W
That's all the T/S numbers i have.
Ported or sealed? Inner volume?
Stuffed?
Must be something between 35, 60 liters. thanks !
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.06872 seconds (64.14% PHP - 35.86% MySQL) with 10 queries
