Old 15th April 2005, 06:52 AM   #1
Greg F is offline Greg F  Australia
Default Woofer cross over frequency
Hi Guys ...
Could anybody out here help ...
I have Jaycar CW2107 6/6.5 woofer Fs 39 Freq 38-5,000Hz
and Jaycar CT2018 tweeter (AKA Vifa D19SD-05-08) Fs 1700Hz Freq 3,000-20,000Hz
Would like to run them via linkwitz 24db active Xover
My question is ... if avarage rule X/o 2-3 times above Fs in this case 1700 for tweeter = 3400 - > 5100 and woofer freg 38-5000 is this ok if I cross woofer so high (have no graphs for woofer)
At present Iam running Jaycars version of 3500 passive crossover from one of there older kits that used CW2107 woofer ...
Thks Greg ...
Old 15th April 2005, 09:35 AM   #2
Gregm is offline Gregm  Europe
Default Re: Woofer cross over frequency
Originally posted by Greg F
Hi Guys ...
Thks Greg ...
I wouldn't. Since you're LR 24ing, why don't you cut the tweet @ 3,4k, rather than have the little woof beaming at you so high.
BTW, even a range of 3,4k -- ~100Hz is rather a tall order for that 6,5", so don't expect heavy bass duties. You may even consider cutting the mid off ~120-150 and plan for a woof/subwoof channel later. Cheers
Old 15th April 2005, 02:30 PM   #3
I think you are struggling.
This tweeter should work from 3.4k up but might be better able to survive & sound nicer from 4k up.
The mid unit will sound pretty ragged if taken beyond 2k and may be poor in the octave below that.
Try a 3k4 xover, but budget for a mid unit to fill that gap.
regards Andrew T.
Old 18th April 2005, 01:38 AM   #4
Gregm, AndrewT
Thks for your reply ...
Might just leave the Xover as is, I did set it to 3410Hz
The drivers are in 24-25 litre ported tower enclosure behind lounge chair in the corner, bass seems OK
Does it matter as much if I let the woofer roll of with high pass filter just to keep cone excursion down
At the moment it is tuned to 40Hz -3db @ 38Hz (no high pass filter) only standard passive filter (ex Jaycar)
Not using the Bass channel of the Xover (Maybe later for sub but not likely no room)
Have tweeter @ 3410 and Mid @ 3410 & I think 48Hz but using this I will give me -3db of 58Hz ... So I was going to change that to 30Hz just to control cone excursion (97db @ just under Xmax) loud enough for that room & more ....
Any thoughts ?
Greg ...
Woofer for hybrid Janszen 750Hz cross-over AR_sound Planars & Exotics 6 1st December 2010 02:29 AM
Active Sub-Woofer and Controller frequency adjustment PetarLD Solid State 3 19th June 2005 04:50 PM
cross over frequency....help!!! Dannyball Multi-Way 16 28th December 2004 05:14 PM
Woofer cut off frequency acenovelty Multi-Way 14 15th August 2004 11:25 PM
Help Needer on Dual Woofer\Mid-Base Cross-Over alvaius Multi-Way 6 2nd August 2002 06:40 PM
Page generated in 0.07638 seconds (85.40% PHP - 14.60% MySQL) with 10 queries
