DIY speakers cables with several non-insulated cores DIY speakers cables with several non-insulated cores - diyAudio
Old 14th April 2005, 10:29 PM   #1
pk is offline pk  Denmark
Default DIY speakers cables with several non-insulated cores
I consider using 0.5mm (app. 24 AWG)) non-insulated solid core silver wire for DIY speaker cables.
However, since the 0.5 mm (24 AWG) is rather thin - even when I only intent to use them for the mid high section – I consider combining 3 cores for + and 3 cores for – for each channel.
Now to the question:
I will try to keep the cores as close as possible and solder them together at each end, but it will be difficult to avoid that one of the cores will “let go” of the the other cores at some time. Will it cause problems if the 3 cores are not all in touch at all times along the cable?
Thanks!
Peter
Old 14th April 2005, 10:36 PM   #2
mastertech is offline mastertech  Australia
Banned
nope other than if you make a mess with it
by the way you sould insulate the cables
Old 15th April 2005, 07:09 AM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
You'll probably get better result if you insulate the 3 cores individually and only join them at the ends.
Old 15th April 2005, 08:33 AM   #4
Default Thanks!
Hi Mastertech and analogue_sa,
Thanks a lot for your replies!
Peter
Old 15th April 2005, 09:28 AM   #5
Gregm is offline Gregm  Europe
Default Re: DIY speakers cables with several non-insulated cores
Unless you have ~50W running through the wire, I'd try it single core first, to get an idea.
Using uninsulted wire is a HUGE hassle, I've tried it (you can't listen, you're always worrying that a ghost will pass by and short the wires!). See if you can't get the wire with some insulation (enamel maybe?) -- otherwise thread it through some (teflon) tubing to be on the peace-of-mind /safe side. Cheers
Old 15th April 2005, 08:27 PM   #6
Hi gregm,
Thanks a lot for your suggestions!
Don't worry, I will insulate the wires somehow. I just wondered whether I could avoid insulating each wire separately which would be a lot of work:-)
Peter
DIY speakers cables with several non-insulated coresHide this!Advertise here!
ferrite cores on analogue cables DECKY999 Everything Else 3 18th March 2008 06:05 PM
what cables do you use in your speakers? legendaryfrog Multi-Way 8 20th November 2006 03:34 AM
Making speakers cables and interconnects from foil inductors JCoffey Everything Else 4 5th February 2005 12:05 AM
Cardas SE15 speakers cables BTW Chip Amps 0 13th November 2004 02:49 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright ©1999-2017 diyAudio
