As you know, I'm looking into upgrading my speakers to be used with a 300B
SET amp. I have enough volume from the present 88dB ones, but conventional wisdom suggests a bit more efficiency may improve the sound quality. Package and WAF considerations pretty well limit me to 6.5inch drivers (as the current S3TLs). In looking for more efficiency, paralleling up the mid/bass drivers is a common way to do this and evidently it can work very well. But here's my confusion. Paralleled drivers will have half the impedance, right? So if the bass drivers are simply paralleled, the speakers Z will be about 8 ohm above Xover freq and about 4 ohm below it. If one driver is rolled off above say baffle step frequency, then Z will be about 8 ohm above this and about 4 ohms below it, I think. And I guess that, in most cases, 'about 4 ohm' will mean in fact a minimum of perhaps 3 ohms or so? This really doesn't look good, when SETs are said to like a moderately high and fairly constant Z. So how is it that one of the most SET friendly speakers, the Living Voice Avatar, uses this configuration and gets away with it? And the Eros at speakerbuilder.net seems a very good unit for a SET (and looks a really fine speaker to boot). Also there is the Ariel, very much designed for SETs. Anyway, I'm confused. My thinking up to now has been to reject speakers with such highly variable and low impedance, but it seems this may be wrong! My choice to date for a design has been a small TL (6.5inch driver) similar to my present speaker which I like a lot. But I guess I should add d'appolito bass reflex designs to my list of contenders? Any comments to help clear my confusion are welcomed! |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
frugal-phile(tm)
A real set friendly speaker would turn a x.5-way speaker with a mid bass & a 0.5 driver into a 3 way with a single driver above the baffle-step & 4 of the same drivers below it... this gives constant load & BSC compensation. Also improves the midrange because that driver is no longer excursing to cover the bass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
But I'm not sure I understand. So one version of this would be 1 fullrange at the top and 4 identical drivers beneath it with top rolled off at the baffle step? But how does that help impedance if 4 replace 1 driver, since 4 wired series/parallel you wind up at the same nominal impedance as 1?
#5 | ||
frugal-phile(tm)
dave
#6 |
Dave,
May I ask how you connect the 4 woofers? I have a WWMTMWW speaker and whenever I tried serial connection of 2 woofers the sound sucked while parallel connection was OK. Common practice is 2 pairs of 2 woofers connected in series then parallel but I could never get that working well and the bass was totally unacceptable. I have temporarily abandoned the top WW and the SPL of the bottom WW happens to match well with the MTM. But ultimately, using the additional top WW will halve the excursions and hopefully distortions but this is an expensive way to do it because I think I need one more power amp in order to preserve the parallel connection, i.e. 2 separate sets of 2 woofers, each connected in parallel. If I could find the right way to connect them without sound degradation and without requiring an additional amp it would be great. Regards, Bill |
#7 | |
frugal-phile(tm)
A bass reflex? Or did you get the phasing wrong? Or one of the drivers with dramatically different impedancce curve? dave
#8 |
Dave,
It is a BR. I have not tried connecting 4 woofers. My experiments told me 2 woofers connected in parallel sounded substantially better than connected in series. It was night and day. So I did not bother connecting 4 woofers. I guess the reason could be doubling the inductance vs halving the inductance. When connected in parallel, the inductance is only 1/4 comparing to serial connection. My amplifier has a 200,000uF capacitor bank and a huge transformer (plus massive heatsinks of course) so should be capable of driving drivers in either connection. This may not be due to back EMF as Svante proved somewhere in this forum that back EMF is the same with either connection. Regards, Bill |
#9 | |
frugal-phile(tm)
My recent experiences (with tube amps mind you) is that series connection sounds better. dave
#10 |
Dave,
Thanks for your replies and I will certainly do my tests once again. Regards, Bill |
| 90 % completed - not dial-up friendly | Madmike2 | Car Audio | 11 | 20th October 2007 04:29 AM |
| SET Friendly Bookshelf | was ist los? | Multi-Way | 4 | 16th November 2004 02:36 AM |
| Friendly?? | grataku | Everything Else | 16 | 24th January 2002 02:55 PM |
| Page generated in 0.12795 seconds (81.64% PHP - 18.36% MySQL) with 10 queries |
