Old 12th April 2005, 06:53 PM   #1
Default Line array wiring suggestions
It’s almost time to wire up my line arrays and I was pondering if I should go with a 3.6 ohm load on the woofers or a 14.4 ohm load. They’re 6ohm drivers, 10 in all, with a Fountek JP-2.0 tweeter in the center. They’re 89db/2.83v so my rough guesstimates yield a sensitivity of 101.5db @ 3.6 ohms and 95.5db @ 14.4 ohms. These will be using a Behringer DCX2496 active crossover.
3.6 ohms = a-a-a-b-b-T-c-c-d-d-d
14.4 ohms = a-a-a-b-b-T-b-b-a-a-a
I doubt I’ll ever have to put more than a few watts into the woofers so I was leaning toward the 14.4 ohm configuration. However, if I ever decide to give them away and use a passive crossover on them the 3.6ohms would be helpful in dealing with BSC due to the higher sensitivity of the woofers. The Fountek, if I remember correctly, is 98db/1w.
Thanks for any input!
Old 12th April 2005, 11:14 PM   #2
Thanks for the input so far!
I thought I'd upload a picture I took 5 minutes ago. I just got the baffle flush and used the roundover on the cabinet. Not too shabby for a first time woodworker, eh? I know this is probably an insane project for a first timer, but I really wanted to make my first pair of speakers stand out and be worth all the time and effort. Thanks again to everyone who has given me input and suggestions!
Old 12th April 2005, 11:24 PM   #3
3.6 is mighty low and 14 is kind of high. How about:
aaaa b t b aaaa
That should get you 6 ohms.
Old 12th April 2005, 11:28 PM   #4
By the way, the cabs look very nice. It's a shame that LA's are your first project because you will never build anything else...
...with the possible exception of open baffle line arrays. I can't wait to hear about your first listening experience. Keep us posted.
Line Array diy suggestions ultrakaz Multi-Way 4 14th January 2011 11:41 AM
line array wiring info. J.k.Wilson Multi-Way 3 26th August 2005 04:15 AM
Looking for line array suggestions Danse Multi-Way 19 21st July 2005 03:38 PM
line array wiring question mcargill Full Range 9 14th January 2005 09:34 PM
wiring a line array loudspeaker vangre Multi-Way 1 6th December 2003 11:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
