Fullrange/TML/Good efficiency
Old 12th April 2005, 05:29 PM   #1
AudioAngel is offline AudioAngel  Germany
Send a message via ICQ to AudioAngel
Default Fullrange/TML/Good efficiency
Hello!
I want to build a Transmission Line with an Fullrange-Driver. The lower cutoff frequency of the loudspeaker should be 60Hz or lower and I want high efficiency, so something like a 5"-Driver wouldn't be the right choice. Are there any suggestions, which driver I can use?
Greetings,
AudioAngel
Old 12th April 2005, 05:55 PM   #2
joensd is offline joensd  Germany
this one´s <<60Hz : http://geocities.com/rbrines1/ . Check out the FT1600.
If that speaker is too big for you check out this :
http://www.diyaudio.com/forums/showt...threadid=46934
(this one has lower efficiency though)
greets
jens
Fullrange/TML/Good efficiencyHide this!Advertise here!
Getting good Efficiency and smooth response, to 3-4-5-way, or not pjpoes Multi-Way 86 31st July 2008 10:56 PM
150 Watt / 8ohm @ 30V or 55V with good efficiency? didifeed Solid State 27 23rd February 2005 07:36 PM
Someone know a good fullrange PA design ? darkm4n Full Range 40 16th January 2004 09:15 PM
