methods for sealing/finishing mdf other than laminating?
Old 12th April 2005, 12:25 PM   #1
lunchmoney is offline lunchmoney  United States
Default methods for sealing/finishing mdf other than laminating?
I've heard line-x truck bedliner works, but haven't figured out how you would DIY.
Old 12th April 2005, 12:34 PM   #2
sinus is offline sinus  Germany
sinus's Avatar
i just finished a fullspectra speaker in MDF pure.
the finish is very nice when the MDF is clear and not a kind of orange.
Chris
regards
Chris
Old 12th April 2005, 12:47 PM   #3
sweet!
Are those full range drivers? Or are there tweeters elsewhere?
My concern is for mobile dj'ing, concerned about what happens if it gets wet, hoping for some method of finishing.
Old 12th April 2005, 12:48 PM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
That looks great, but I think 95% of people's woodworking skills aren't good enough not to need any filler or blemish hiding
If it's for mobile DJ use you should be using plywood anyway as MDF is too heavy and ruins if you drop it or catch it with any bits of kit.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th April 2005, 12:58 PM   #5
using the mdf partly because it's free, and I'm putting steel corners on it, so not too concerned.
Any methods for finishing?
thanks
Old 12th April 2005, 01:29 PM   #6
sinus's Avatar
re
this are full range drivers (Visaton B200). the finish is a colourless ground coat to cure the surface and then two coats of varnish. i didnt use filler.
no problem for raining
But for PA there is maybee better solution.
Chris
regards
Chris
Old 12th April 2005, 04:16 PM   #7
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Default Re: methods for sealing/finishing mdf other than laminating?
Just buy bed liner spray cans at the store, Wal-mart for instance.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 12th April 2005, 04:20 PM   #8
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I would be very concerned about using MDF for DJ work. I would take all steps to avoid it. It is not suited for moving around. Spend money on plywood. Metal corners are only delaying the inevitable.
Back to your question. About the only thing you can use if you still plan on MDF is sheet vinyl. That will protect it better than any coating. Truck bed liner is OK but it's not vinyl.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 12th April 2005, 05:20 PM   #9
I hear ya regarding plywood vs mdf...I'm sure you're right...
But bear in mind that this speaker is only about 12" x 12" x 18", all wood glued with no screws, using tongue and groove joints. This thing will be seriously overbuilt. Not worried. If the cabinet were larger I'd be more concerned.
If it breaks I'll build another one out of plywood and say "damn I should have listened to that guy" . Thanks.
Old 12th April 2005, 05:29 PM   #10
leadbelly's Avatar
Your method is actually WEAKER than just butt joints with screws.
MDF is weaker than plywood in every way: shear, tension, compression. It is much weaker than plywood in shear, so when you cut some of it away to make the tongue & groove joint, you will create a weak point right there in the thinner section that will break when dropped.
methods for sealing/finishing mdf other than laminating?Hide this!Advertise here!
Laminating cabinets Cal Weldon Multi-Way 108 20th May 2011 04:50 AM
Paint damage from sealing drivers with silicon, what to use for sealing drivers? DexterMorgan Multi-Way 21 12th February 2009 12:46 PM
laminating Hedlund Horns KMMM Full Range 10 19th December 2007 12:30 AM
Aluminum panel finishing methods ashok Parts 7 2nd June 2006 07:56 AM
laminating glass tade Everything Else 8 4th March 2006 08:56 PM
