Old 10th April 2005, 01:57 PM   #1
Default Port Tuning
Is it possible to experimentally tune a port, because in all of the simulations are a bit different and very short (2 inches?) for a 28hz tuning?
So could I try a bunch of different tunings and see where it is the most agreeable?
Old 10th April 2005, 02:07 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
When ports are that short, there can be significant error in the calculations due to the approximate nature of the end corrections. You would be better off using a larger diameter port - which would require a longer tube.
The proper formula (from first principles except for the end corrections) is:
Lv = 2361*Dv^2/(Fb^2*Vb)-K*Dv
where K is 0.85 for a tube flanged at both ends (or shorter than ~50mm)
and K=0.73 for a tube flanged at one end and free on the other.
Lv is port length in mm and Dv is port diameter in mm - Vb is box volume in liters.
If you want to tune by listening and experiment - go ahead....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 10th April 2005, 05:57 PM   #3
I am using a 4" flared port, I don't think it gets much larger than that (that I have seen).
Maybe there is something wrong with my calculations?
Old 10th April 2005, 09:35 PM   #4
Svante is offline Svante  Sweden
Svante's Avatar
If your box is about 270 litres, the calculation are correct. Still, such a short port is very easily overloaded. Try using several ports instead, maybe 4 of them. Then the port lengths should be 280 mm, which is far better in terms of overload margin.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 10th April 2005, 11:06 PM   #5
Ron E's Avatar
To help you design your box, you really need to give more information, like what teh woofer T/S parameters are at the very least. Especially important in choosing ports is Sd (cone area) and Xmax (excursion).
Wiht a box that large, you are probbaly using a large woofer or several of them. There is more to port design than just figuring length - it is best to model port velocity and try to make sure it will stay below ~17 m/s at the highest listening level you will be using. As SVante says, it will probably take multiple ports.
Old 10th April 2005, 11:13 PM   #6
I am going to have 2 10" Dayton RS270s in a 214 liter box, with around 15 liters going into a subenclosure for the mid, and has 5 pounds of polyfill in it.
I have a hole made for the 4" flared port. which is around 6.5" at the outside end around 5 or 5.5 inch diameter on the inside flare.
The T/S parameters are found at http://www.partsexpress.com/pdf/295-368z.txt
at the bottom.
Thanks for all of your help!
Old 12th April 2005, 04:23 PM   #7
Does anyone have an idea for me?
I think the port mach for a single 4" should be fine, however it's just so short, is there anyway I can fix this without purchasing another port? I already have enough budget overruns.
Old 12th April 2005, 11:07 PM   #8
Ron E's Avatar
You may be right, one port will be close - best if rear-firing, though. I would forget about stuffing teh box - stuffing is not required in ported boxes. Line the walls with ~2" of foam or fiberglass instead - or put the stuffing in a net and staple it to teh walls..
If it were me, I'd make the port about 5" long. But leave room to experiment.
Old 12th April 2005, 11:56 PM   #9
My port is rear firing, but all of my calculations say like 2.5 inches, where are you getting 5" from?
Old 13th April 2005, 12:08 AM   #10
Oh and the boxes are already stuffed, there is nothing I can do about that, they are sealed up.
Tuning port on MLTL : how ? sadhill Full Range 7 8th October 2008 07:43 PM
What’s going on with my port tuning? Brownee Multi-Way 28 19th May 2008 07:46 AM
Question about port tuning ostie01 Subwoofers 3 26th September 2005 01:30 AM
MLTL port tuning Josephjcole Full Range 9 4th August 2005 01:22 PM
newbie port tuning elfman222 Multi-Way 1 27th February 2003 03:53 AM
Page generated in 0.10180 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
