I just got the drivers and plans for a Shamrock SE-2 from a member of the forum.
The crossover diagram seems odd though. It's got a series RCL shown across the amp terminals. The values are 8ohm, .25mh and 35mfd. Resonance calculates to 1700Hz. Weird. If anyone has a schematic for this I would be greatful for a copy. A verbal description would serve as well. Alternatively, a crossover design for a MTM using Vifa P17WJ008 and D27TG45 would be nice. Thanks |
#2 |
It's not weird, it's an excellent design.
The RCL network is a conjugate which "reverses" the reactive nature of the crossover network and makes the load look more resistive. Beneficial for tube amplifiers mainly. With a good solid-state amplifier the system should fine with or without it. The SE-2 IS an MTM design for P17WJ008 and D27TG45. You're looking for alternatives? Cheers, Davey. |
#3 | |
I'll try Shamrocks crossover design first unless you know of a better one for these drivers. Thanks |
#4 |
Some web research indicates that the designer of the crossover in question was affiliated with Lynn Olson, a heavy tube user. Mike McCall of Shamrock was in Silverton and Lynn in Portland, Oregon. So, the xover design makes a lot of sense when one considers the tube interest mid 90s when the SE-2 was developed.
#5 |
Hi Bill,
Funny, I just got back from Eugene. Good to see you weren't riding your motorcycle around MLK last night (reference to your old avatar). I would be interested to hear about your impressions of the Shamrock loudspeaker when you finish building it, although it looks like Shamrock doesn't sell the plans anymore. What is the sensitivity of the SE-2? |
#6 | |
Well, the mid/woofs are 88db and they're wired in parallel. But then considering BSC, if there is any, we're back to 88. Frankly, I haven't been able to find what I really want in a satellite unit so I'm just poking around with the lesser choices. |
#7 |
Account Disabled
I have plans for SE-1 and SE-2. BUT, I don't have nice words for SE-1. I've been realy disapointed in crossover and box plans. Then I change the crossover, make some arangement in the box and SE-1 now realy sings...
Maybe is SE-2 better, i don't know... Drop me email for plans. Boban |
#8 |
Early KEF speakers used conjugate load matching; they make almost any amp perform optimally. I wonder why this is not used more often??!!
Sam |
#9 |
Bill,
I would try the SE-2 schematic as-is. Admittedly, this set of drivers is rather mediocre and boring relative to the current drivers preferred by the DIY crowd, but the performance is quite good considering the price...IMHO. Also of note regarding both the SE-1 and SE-2 is that the design of the D27TG45 tweeter changed slightly after the initial crossover design by Mike. However, I'm not sure how much relative difference this made since my speakers used the earlier tweeter and measured excellent. Cheers, Davey. |
#10 | ||
| Shamrock SE-1 or SE-2 | t3knique | Multi-Way | 0 | 4th August 2009 02:00 PM |
| PLS-226 Schematic | Tequila | Solid State | 7 | 6th May 2007 10:07 PM |
| Art SLA-2 schematic | Taifun | Solid State | 1 | 8th May 2006 06:58 AM |
| Pre amp? What schematic do i need? | silentblackhat | Solid State | 21 | 16th March 2006 06:47 AM |
| What do you think about this schematic? | DaveWeckl | Solid State | 4 | 15th February 2004 10:32 PM |
| Page generated in 0.10695 seconds (80.72% PHP - 19.28% MySQL) with 11 queries |
