#11 |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
Hi!
Thanks, I already read the infos on the Klang-form akustik's site and also the dialog of Till Roemhild on the: http://www.audiomap.de/forum/index.p...id/19186/page/ My question is: Am I undersand theirs BLH method well?: -the BIG pressure chamber behind the driver is tuned to the driver Fs. So Fc=Fs=55Hz ( The horn will amplify only the frequencies under the Fs and there will be no interferency between the horn's and the driver's direct radiations.) -the Horn mouth tuned to 35 Hz = 4500cm2 -the horn lenght tuned to 45Hz = 1.2 m (?) ,but 1.2m=71Hz (!) and 1.91m would be the correct lenght for 45Hz. Are They sum up the pressure chamber lenght with the horn lenght to get the 1.9m? Tyimo |
#14 | |
frugal-phile(tm)
as an example.... for free space loading, the horn would need a diameter of 1566 mm to reach 35 hz Sitting on the floor you could divide the area in half. dave
#15 |
Yes,offcourse, but what about the short horn line lenght?
Tyimo |
#16 | |
frugal-phile(tm)
dave
| Using PVC Pipe For A Back Loaded Horn | JimOfOakCreek | Full Range | 13 | 15th April 2008 07:30 PM |
| Back loaded horn bipoles? What? Why? | kaltsoplyn | Full Range | 6 | 19th February 2008 11:37 PM |
| Front loaded and back loaded horn | DrWoofer.com | Subwoofers | 0 | 3rd August 2007 06:55 PM |
| Back Loaded Horn Calculations | Tyimo | Multi-Way | 3 | 15th March 2005 03:34 PM |
| Would like details of this Back Loaded Horn | mrlots2do | Multi-Way | 7 | 16th January 2005 02:54 AM |
