Old 3rd April 2005, 07:46 PM   #1
BorisH is offline BorisH  Germany
Default Please comment on this enclosure
I like this design because it looks good and doesn't offend my other furniture. Internal volume is 5l, height 70 cm (27.6 inches), the baffle is slanted and aims at the listener. Driver's diameter are that of a Seas L12 woofer and a Seas 27* or 25* tweeter. A vent will be placed on the rear side behind the tweeter.
I have another design with the woofer on top here
http://www.audiodiskussion.de/foren/....php?idx=43995
The design with the woofer on top places the tweeter in a more favourable position what edge diffraction is concerned. On the other hand, it moves the tweeter closer to the floor. Still, I tend to prefer the woofer-on-top design as I may tame the early reflections by a carpet.
Concerning phase alignment, there's no difference between the designs. Since the listener is on axis with the drivers, the time-aligned axis is either below or above the listener (unless sitting on the floor).
So, what do you think of this enclosure?
BorisClick the image to open in full size.
Old 3rd April 2005, 07:52 PM   #2
karma is offline karma  Canada
karma's Avatar
im thinking i would like to make a set
i like em.
Old 3rd April 2005, 10:18 PM   #3
Speakerholic
Cal Weldon's Avatar
I can't see the pic
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd April 2005, 11:22 PM   #4
5th element's Avatar
I cant see the pic either but it you right click on the picture and copy the URL and paste it into your browser it will load the pic.
Yeah they are a nice shape etc only thing is all those angles would be annoying
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 4th April 2005, 04:17 AM   #5
It looks very nice. Now, its sound must be as fine as the unit looks. Have you designed the crossover?
You must do your best to get it.
Congratulations.
Old 4th April 2005, 02:09 PM   #6
Thank you for your comments.
If you can't see the picture it's here:
http://www.exdreamnet.de/forum/user/Boris/ls.jpg
It's the one with the woofer on top.
What do you think of its acoustic properties? I want to use it for John Krutke's Seas L12 system.
Old 4th April 2005, 02:26 PM   #7
OK JK's L12 system has its bafflestep compensation built around the width of the cabinet. If you make sure to keep the baffle width, enclosure volume and port tuning the same then yes it should work well.
Old 4th April 2005, 02:44 PM   #8
Default L12 system
Dear Borish:
I agree with 5th element about the sharp corners the front baffle has. You may add some labor making them round.
I do not know anything about the L12 Seas system, are you able to provide some mora data?
I will appreciate it.
Hugo
Old 4th April 2005, 03:25 PM   #9
bwbass is offline bwbass  United States
Here it is. The original image link had an extra "/" in it. Nice design!
Please comment my PCB! Mlaen Solid State 31 11th February 2009 09:35 AM
please comment my pcb sakis Solid State 15 28th July 2008 08:24 AM
Please comment my pcb P3a roly3055 Solid State 52 18th February 2007 02:45 PM
Please comment for my new CFB amp lukio Solid State 11 9th February 2004 03:59 AM
Page generated in 0.12175 seconds (71.70% PHP - 28.30% MySQL) with 10 queries
