I am going to build a center channel, and I have several extra tweeters.
I was going to do an MTM, but I could build an MTTM. I cant find much info on this.
I am thinking of something similar to this.
Do I approach this as I would a regular MTM?
The goal is wide dispersion and clear dialogue.
I have SW to do measurements and crossover simulations.
Generally, it's a bad idea. However, it can be done. The sole benefit is slightly higher power handling and lower crossover point. There was a discussion on Madisound a while back.
The wrong way to do it is to simply parallel the tweeters. The right way to do it is described by Paul Hilgeman below.
http://www.madisound.com/cgi-bin/discuss.cgi?read=335861
I've used the same concept on midwoofers for a sideways MTM center channel with limited baffle step but better lobing tendencies.
Generally however, it's better to use a small dedicated midrange below the tweeter, such as a Morel MDM55, a popular choice in a center channel W-T/M-W config.
Axiom speakers use dual tweeters in the worst way possible. See below.
