Old 3rd April 2005, 07:46 PM   #1
Question Help me build an active monitor for dj'ing
(also posted in "everything else", wasn't sure of best place to put it)
Hey there,
Total noob here...
I'm looking to build one self-powered monitor specifically for mobile dj'ing. This is for putting in the dj booth with me, pointed towards me, so I can hear what I'm doing. Essentially, whatever the crowd is hearing is what I'll be hearing through this monitor.
Requirements:
- 8" or 10" woofer
- not sure what size or type of tweeter I should use
- INTERNAL amplifier(s), ideally bi-amped
- 100 Watts rms minimum (combined power of both amps)
- bass, treble, and volume gains
- RCA inputs at the very least, 1/4" would be nice too
- rugged construction for mobile dj'ing
- don't want to spend more than $300 on components and materials
- doesn't need to be studio monitor quality, it just needs to get the job done and be reliable
The holy grail would be to duplicate a Mackie SRM350 (obviously not the molded ohusing). I'm sure it's unrealistic for me to build a speaker of this caliber, but check it out and it'll give you a sense of the basic specs I'm after:
http://www.mackie.com/products/srm350/index.html
I'm new to the world of building speakers, but I have a lot of experience in a model shop, and I have a model shop at my disposable with every tool under the sun. The tools and the craftsmanship are there, just not the specific know-how for speakers. I'm sure it's unrealistic for me to get into the hardcore intricacies that you guys do, but I'm sure that if I had the right components and some advice on assembly I could get it done.
Please kindly help me with:
- recommended components and where to get them
- how-to advice or links to how-to advice
- an assessment of whether I'm in over my head or not
THANK YOU!!
Old 4th April 2005, 04:05 AM   #2
G4ME is offline G4ME  United States
Send a message via AIM to G4ME
might be better in a different forum, but i will give a suggestion, 300 isn't that much for a pair of monitors, but I have a pair of Pi Speakers Studio Series II, they have decent bass but the low end is pushing it for the Eminence drivers, but for moderate listening they are really nice. I also have the previous version, the ones with a piezo tweeter and i can only imagine that the Vifas they replaced them with make the top end much much better.
Two little mice fell in a bucket of cream. The first mouse quickly gave up and drowned. The second mouse, wouldn't quit. He struggled so hard that eventually he churned that cream into butter and crawled out.
Old 4th April 2005, 06:55 AM   #3
thanks
which forum do you think would yield more responses?
Old 4th April 2005, 07:45 AM   #4
Did it Himself
richie00boy's Avatar
Ask a moderator to move this topic to the Loudspeakers forum
Do you only want a single speaker? It's not clear from your oroginal post if you want a pair. I think you need to be looking at a 10 inch drive unit if you only want one speaker. I guess the Eminence range is the place to start looking. Don't be concerned about power handling figures, they are largely nonsense and irrelevant.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th April 2005, 08:11 AM   #5
pinkmouse's Avatar
No need to ask
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 4th April 2005, 10:27 AM   #6
Banned
These are already built -- $369.00 Pair
- 2-way Bass reflex cabinet manufactured with a rugged, high-quality Poly-Resin material.
- 12" High Output, Long Throw Woofer with treated cone and high temperature voice coil (3" VC diameter ->58.8 oz magnet!).
- High Efficiency Light Weight 1 1/2" Pure Titanium Wedge Compression Driver with True Formtm 90° x 60° exponential horn tweeter.
- Inputs/Outputs - 1/4" jack Mic-In,RCA Line In/Line-Out, XLR In/OUT
- Bass/Treble Controls
- 260rms/500 Watts Amp Music Power
- Size: 25.0"(h) x 21.5"(W) x 14.2"(D)
- Adjustable Frequency Response: 45~20KHz
- SPL: 95 +/-2 dB
- Weight: 40lbs each
- Strong side carrying handle.
- Steel grill.
- Hard-rubber feet.
- Adjustable bottom pole mount allows for easy tripod mounting.
Old 4th April 2005, 12:18 PM   #7
Thanks guys.
Just one monitor...(read it again )
As for those 12's, they're simply too big. Often there is limited space to put the monitor.
Old 4th April 2005, 12:30 PM   #8
5th element's Avatar
I think for $300 you will be hard pressed to get what you want out of it
You are going to want to build two power amplifiers an active crossover, the loudspeaker cabinet finished with some sort of heavy duty design, the drive units themselves etc. The amplifiers will require a power supply which is likely to cost alot unless you know of where to get bargain stuff.
The speaker posted by Magnetar is a good idea, mass produced stuff can do things cheap, like power supplies amplifiers etc.
This is rather adventurous for a 1st time project and not one I would recommend on a budget. If you wanted to build a passive version of this then I would say its doable but including all those electronics stretches the budget too far. Youd be surprised of all the other things you will include or use that will bump up the price.
Actually your best bet may be to hunt down a cheap and cheerful budget amplifier and use that as the main box of tricks. Most come with all the features you could need and will also have a preamp section already with suitable voltages for an active xover of your own design. Or you could just use PLLXO's, high pass on the left channel, low pass on the right channel then feed the drive units from the suitable output. How much can you get a budget integrated for on clear out in the states? Adding a PLLXO to one should be cheaper then making all your own electronics right? a £50 sale at richersounds would be cheaper over here then if I had to make all my own amps and xovers.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 4th April 2005, 01:33 PM   #9
audiobomber's Avatar
Default Re: Help me build an active monitor for dj'ing
THANK YOU!!
I'm thinking along the same lines as Magnetar. DIY'ing an active speaker is no trivial matter, and probably best left to someone interested in the hobby for its own sake, rather than to fulfill an imminent business need.
I'd recommend a pair of these Berhringers. I've never heard them, but as you stated, you don't need super-fi. They're at your budget for a pair, but you could sell one, or keep it as a spare.
http://www.partsexpress.com/pdf/248-640s.pdf
Good luck,
Dan
Old 4th April 2005, 01:37 PM   #10
Did it Himself
Well, maybe a little ambitious
$30 18mm plywood
$20 covering enclosure
$10 enlosure handles & tophat
$80 bass-mid
$30 tweeter
$80 bass-mid amp
$50 tweeter amp
$50 input, crossover etc circuitry
$350 total
Budget Active nearfeild monitor: Edifier R1200 DcibeL Parts 0 18th February 2009 05:38 PM
The Box MA1220A Active Monitor Schematics needed alexclaire Solid State 1 6th February 2009 08:32 PM
Active crossed mini monitor sugestions G4ME Multi-Way 10 18th June 2005 02:36 PM
Active studio monitor modifications argonrepublic Chip Amps 0 30th May 2005 10:59 PM
Pix of new diy 10" Active Booth Monitor... lunchmoney Multi-Way 12 21st April 2005 04:08 PM
Page generated in 0.14056 seconds (80.63% PHP - 19.37% MySQL) with 10 queries
