Old 30th March 2005, 12:21 PM   #1
Default Diffrent Speaker !!!
hi all ..
what s diffrence between instrument speakeres , studio proffesional speakers , hi fi speakers & car speakers ???
Rest my eyes from the world.
This dying place, it's so absurd.
Old 30th March 2005, 04:01 PM   #2
Speakerholic
Cal Weldon's Avatar
Think of them in terms of what they do.
An instrument speaker is designed to cover the portion of the audio spectrum that the instrument does.
Studio professional speakers are supposed to be accurate sounding so the engineer can mix the music according to them.
Hi-Fi seems to mean "made for the home"
Car speakers are often designed with the very small listening environment in mind.
They all work on the same principals. Think of them like automobiles. Some are made for speed, some for luxury while others are made for off-road use. They all use internal combustion engines.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 30th March 2005, 06:48 PM   #3
i wanna know what s diffrence between them in their construction ..
example ,, why car speakers arent good in home system , or why hi fi speakers arent well in instrument ???
Old 30th March 2005, 08:28 PM   #4
BobEllis's Avatar
because of their different intended uses, they each favor a particular feature that is often at odds with something desired for another application.
for instance, a MI or Prosoud speaker design typically stresses efficiency and power handling. Great for filling a venue, but accuracy and response smoothness may suffer. The distortion is often part of the desired sound - guitar speakers for example
Car speaker designs take into account that they will get significant bass boost from the small volume of a car. Put them in a living room, and that boost is gone and bass response of the system can suffer. A home speaker in a car may have too much bottom end due to cabin gain. Accuracy of many car speakers leaves much to be desired, although there are some surprisingly good ones.
Home speakers don't need to get as loud and won't generally be driven as hard as MI speakers, so efficiency and power handling can be traded for accuracy, smoother response and deeper bass extension. Play a bass guitar through a home system and it may sound nice, but if you try to gig with it, you'll fry your woofers, and maybe tweeters if you crank in a bunch of distortion. They need a lot more power than a pro driver to reach the same volume but usually cannot handle as much. An electric guitar may sound odd, especially if you are used to one of the highly colored guitar drivers.
The above are generalizations, there are certainly drivers that don't fit this mold, such as low distortion pro drivers that many prefer for their home systems and subs that work well in a car or home.
Hope this helps
Old 31st March 2005, 01:08 PM   #5
thnx man
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
diffrent voice coil palesha Multi-Way 6 25th January 2006 10:26 AM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
Pi Speaker Reviews/or Similar Speaker G4ME Multi-Way 4 17th June 2003 12:26 AM
Page generated in 0.07829 seconds (82.60% PHP - 17.40% MySQL) with 10 queries
