Old 30th March 2005, 07:10 AM   #1
10K2HVN is offline 10K2HVN  United States
Default Transmission Line - "C m/s"
Hello,
I found this link in another thread:
http://www.mhsoft.nl/spk_calc.asp#transmissionline
I was wondering what the "C m/s" input in relation to the transmission line enclosure does?
..is "344" really "ideal"..?
Thanks for your help!
-10k
-[10k]™
Old 30th March 2005, 09:47 AM   #2
MJK is offline MJK  United States
Speed of sound defined as 344 m/sec in air is fine. It will change slightly when stuffing is added but probably will not go below 320 m/sec.
Don't use that calculator for TL sizing, it is not correct.
Old 30th March 2005, 06:05 PM   #3
Thank you very much for your input!
Im just trying to fine an easy way out.. Ill actually read through your site one of these days.....
-[10k]™
Old 30th March 2005, 10:39 PM   #4
Unfortunately, there is no free lunch with TLs. You really need to do a lot more work desiging a TL then a bass reflex or acoustic suspension enclosure. A horn is even more work then a TL. The quality of the design is directly proportional to the effort expended.
Old 31st March 2005, 08:17 AM   #5
at first i was thinking about copying the SEAS THOR TML for dual SEAS Lotus RW165 midwoofers because the woofers are somewhat similar..but after some searching, i found someone said that the enclosure was not well-designed, so now im thinking of designing my own..but i dont know the first thing about them....
ill figure it out someday.... unless someone has a design that will work well for them......?
Thanks for your replys!
-[10k]™
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
3" Driver in a Transmission Line. chris661 Full Range 3 21st August 2009 09:43 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
"log line" and "pressure chamber" skrivis Multi-Way 0 21st April 2005 03:55 PM
8" Quartz pipe for Transmission Line speaker MRehorst Swap Meet 0 26th December 2002 11:00 PM
Page generated in 0.06510 seconds (81.76% PHP - 18.24% MySQL) with 10 queries
