Old 30th March 2005, 01:14 AM   #1
Default wirewound resistors are coils.
Hello.
Im making a attenuation circuit and I notice that not only does
the overall level of the tweeter get less as wanted but also the higher freqs gets duller.Now this might not be so strange since a big resistor usually is a wire around a string with some sort of coating.IE A COIL!
Well a coil paralell with the tweeter would change the overall responce,would it not?
So then I start to think..what resistors would be able to do the job without acting like a coil?
In the mouser catalog there where many options.
What say you audiowizards?What is the best way to add resistance without using coils?
Lots of 1w metal film resistors?
thanks for reading.
H.Honda Chico CA Land of the fooled
Old 30th March 2005, 01:31 AM   #2
Warp Engineer
On Holiday
AudioFreak's Avatar
You can get high power non-inductive resistors.
- Dan
Old 30th March 2005, 01:31 AM   #3
Steve Eddy's Avatar
What you do is use some non-inductive wirewound resistors that use Aryton-Perry windings such as those made by Mills Resistor and stocked by Michael Percy among others.
se
Old 30th March 2005, 10:11 AM   #4
DirkD is offline DirkD  South Africa
Try the Lynx resistors frome Solen - www.solen.ca or Eagle MOX resistors from Madisound. Both sound very good and are cheaper than Mills.
Dirk
Wirewound resistors Mywing Parts 5 24th February 2009 06:27 PM
FS: Used Caps, Coils, and Resistors Rybaudio Swap Meet 4 14th July 2007 12:40 AM
wirewound non-inductive 1% resistors GAK Multi-Way 18 18th September 2003 05:26 PM
magnetic, inductif 5 watt wirewound green resistors lieven Solid State 3 17th September 2003 11:12 PM
Where to find Vishay-Dale NS-10 non inductive wirewound resistors? settriode Parts 3 13th February 2003 09:55 PM
Page generated in 0.13712 seconds (41.86% PHP - 58.14% MySQL) with 10 queries
