hi, some of you may recall my thread when I asked about how to repair the surround on my paradigm monitor.
last nite i dug the driver out of storage, and saw that it was in worse shape then I remembered. the centre dome or cone was been pushed inwards, and then the accordion like material that you can see when you look "inside" the speaker, i think it like attached to the voice coil, it is torn or ripped, in a perfect circle near the middle. is this thing trash or could it be fixed? i am willin got take it to my local speakermart, but maybe it would be just as cost effective to replace it with a new one. also, dont you normally have to replace them in pairs? ie i would have to also replace the one in the other cabinet that is not damaged? |
#2 |
If there is a substantial amount of rebuilding required, then yes, it is best to have both rivers done at the same time.
First find a speaker repair man, then get a quote and then you can decide if it is worth repairing or whether it is better to buy new.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
If you ever have a speaker with a foam surround where the foam has deteriorated (sunlight damage in the rear car shelf) but is still in tact, you can try what I have which is to squeeze puncture repair (rubberised) glue onto/into the foam. The foam absorbs far more than you may think, and it can be spread with a finger or a brush. It does take a while to set, staying tacky for a few weeks, depending on the temperature etc. But the result is surprisingly strong (stronger than new?). I am no speaker expert, there must be a change in the characteristics ie compliance, I have often wondered if it would be beneficial to add this glue to a new speaker to reduce the effects of sunlight, or to modify characteristics(?). I doubt that many quality drivers use foam surrounds, (mine were out of two different cars) but I thought the idea may be of interest to someone.
| Speaker repair.. | stevef51 | Multi-Way | 5 | 28th October 2008 08:23 PM |
| Speaker repair | patknk939 | Multi-Way | 17 | 16th February 2008 09:44 AM |
| Speaker Repair | dscrobe | Multi-Way | 7 | 11th October 2007 11:44 AM |
| speaker repair | aarono | Multi-Way | 2 | 19th November 2005 04:30 PM |
| Speaker Repair | bhg41088 | Multi-Way | 0 | 17th December 2004 12:57 AM |
| Page generated in 0.07342 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
