Old 29th March 2005, 12:23 PM   #1
tinkerbell's Avatar
Send a message via AIM to tinkerbell Send a message via MSN to tinkerbell Send a message via Yahoo to tinkerbell
Default driver modification - extreme?
if i am going to the trouble to flush mount my 6.5in drivers & bevel the edges of their 'bookshelf' boxes,
i just found out by searching that there is a issue that relates to edges & how sound is defracted,
will the protruding edges of this particular driver be better off removed? (it is layered paper)
i note most high end drivers surround is as flat as possible, with the rubber as close to the edge as possible.
is it worth the effort/risk of damage to remove the edges?
Old 29th March 2005, 01:20 PM   #2
Mjr7531 is offline Mjr7531  United States
Mjr7531's Avatar
Usually they glue the edges to the surround, so if you do choose to remove the edging, be very very careful, as if you are not, you will remove the surround from the frame.
Old 29th March 2005, 01:48 PM   #3
Mr Evil is offline Mr Evil  United Kingdom
If the size of the edging is small compared to the wavelength of the highest frequency the speakers will reproduce then it will have no significant effect. Thus for tweeters it is important to keep things smooth, but for woofers it's mainly just for cosmetic reasons (assuming it doesn't obstruct the tweeter...).
https://mrevil.asvachin.eu/
Old 29th March 2005, 10:29 PM   #4
tinkerbell's Avatar
thanks MrEvil - the discussion that prompted the question was far too detailed to have discussed basic realities such as wave length.
it makes sense that the woofer wont produce frequency that is short enough to be interfered with,
and since the woofer will be flush mounted - it wont interfer with the tweeter
cheers!
Driver modification query Moondog55 Multi-Way 19 15th February 2009 11:40 PM
any modification can be done for speaker Driver protection using LM3886 rhythmdiy Chip Amps 0 23rd October 2007 06:16 PM
Modification of a driver kaan Multi-Way 10 19th October 2007 09:09 AM
Extreme DAC 3.0 martioz Digital Source 3 11th March 2003 10:45 PM
Really, really extreme phono, more extreme than mine peranders Analogue Source 34 22nd October 2002 11:59 PM
Page generated in 0.06007 seconds (82.54% PHP - 17.46% MySQL) with 11 queries
