I am trying to build a subwoofer around 4 of these 8" Onkyo's:
http://www.apexjr.com/speakerstuff.html (scroll to the bottom to the 8" Onkyos.) Specs given are: Onkyo 8" Butyl/poly cone 100Watt RMS 4 ohm30Hz-2Khz Vas 14-16 Ltrs QTS .581 and X-max 6mm used in the Aperion Audio Imunus S8 8" powered Subwoofer: I want to use 4 of them in a Tall floor stander in an ISOBARIC configuration. On the outside only 2 woofers will be visible but will be "helped" by 2 additional driver in the rear, configured in an Isobaric arrangement. Question: To get a -3db roll off at 30Hz, what enclosure size am I looking at for both the main and the Isobaric areas. The rough shape I am looking at building is in the MS paint diagram (pls excuse the bad quality... I do not have a modelling software) attached as zip. I'd like a profile thats not more than 10" wide and 14" deep. Can anyone help?
#2 |
Now that I have read a few other posts, I am open to any 8-10" sub (4 ohms) for the Isobaric design.
My objective is deep (non-boomy) bass in a small foot print. Thanks a bunch in advance... |
#3 |
OK, guys please slow down, I am overwhelmed by the flood of responses...
#4 |
Not many people are interested in opening zip files.
#5 |
Not enough parameters to model a box.
Nice looking speakers though. I would probably build a box like this feller did; http://www.betteraudio.com/geolemon/isobp/isobp.htm Or if you still want a sealed I'd build it clam shell with two equal sized chambers, no ports but the center would be open ( no plexiglass)... It would sort of look like a horn type speaker.. Another site for ideas; http://www.jlaudio.com/tutorials/isobarik/clam.html I wonder if you contacted Apex Jr. if they could supply the rest of the parameters or an idea to a box size. Isobariks are usually 1/2 the size of a modelled speaker closed or ported. |
#6 |
Thanks RJ
I think I am going for something like the Piggy-Back arrangement if I go Isobarik. I am not a bandpass fan. These will be for a home/ music system, so aesthetics are also important. If not Isobarik, and I go four 8" ers in a line array, do you have any suggestions for woofers/ enclosures with known parameters, good looks etc that I can scale up? Bill, for you only RJ, I have written to Steve for T/S lets see. thanks guys. |
#7 |
I just saw this, since I was looking for a 8" wide driver, perhaps I could use 2 of these: http://www.tb-speaker.com/detail/1208_03/w8q-1071.htm
Has all T/S on the web-page. What size enclosure am I looking at for a single driver -3db at 25-30Hz? (I will extrapolate the Isobric enclosure from that). thanks! |
| newbie Q | memphissound | Multi-Way | 7 | 17th August 2006 11:36 AM |
| Yet another newbie | hell0un1verse | Introductions | 1 | 30th March 2006 05:31 PM |
| Newbie w/ sub ?'s | toenail | Multi-Way | 2 | 8th March 2003 01:10 PM |
| Newbie needs serious sub help | AcidRain | Multi-Way | 4 | 7th March 2003 07:07 PM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.09426 seconds (74.60% PHP - 25.40% MySQL) with 11 queries |
