I've got a copy of edge.exe. It asks you to input a resistance value. Should that be the Re of the driver? The nominal impedance? The impedance at the baffle step frequency? Or what?
I don't suppose there is a program out there that takes into consideration both the baffle dimensions and the distance from the back wall is there?
