#61 | |
Davy Jones |
#62 |
I just discovered that I accidentally modeled the wrong Aura speaker. The one that was actually suggested would seem to be just the ticket. Do they actually achieve those T/S parameters? 80Hz Fs? Yikes.
So here we go. The Bo$e satelite has been reported to be 3"X5"X6.5" OD. Using 1/4 inch material, that yields an internal volume of 67.5in^3. The Aura NS-193-8A in that volume gives a Qts of .98 and could be crossed over in the 90 to 100Hz range. Wow. That doesn't just beat the B--se, it humiliates it. The front would have to be a little wider than 3", because it's a 3" driver, not a 2.5" like the B-se. So, a little wider it will be. We are in the right ball park. And the box can be made effectively a little larger with aperiodic venting and stuffing. Now then, there's the sub to think about.
Davy Jones |
#63 |
Since she's into art, you might want to rethink small and go for exotic instead. For example a nice pair of suitable drivers on flat OB's. If she's into modern art, maybe glass baffles. If that's not her style, then stretch a canvas across the baffle and with a grill, hide the speaker in the painting. Another good one would be the Cornu spiral horns, which hang on the wall and can double as a painting too. With those horns, a sub may become unnecessary. Small and cute is one thing, but for an art studio really cool would be much better. Plus she'd be able to make them her own creation. It might even turn into a money making art project. A subwoofer that doubles as a base for a sculpture piece or a sculpture that has a sub built into it are possiblities too. Be creative, or if you can't, let her.
Everyone has a photographic memory. It's just that most are out of film. |
#64 |
I found the actual dimensions of the Bo$e AM-15 on the net. 3 1/8 X 6 3/16 X 4 1/8 for the satellites. The little Aura 8A will do okay in that.
The bass module is much larger than I expected it to be. Over 1 1/2 cubic feet internal, I would guess. That's enormous for what it accomplishes. O.D. 8 1/4 X 16 5/16 X 29 1/8. So how about some suggestions for the bass module?
Davy Jones |
#65 |
Dave,
I don't know the Qt of the driver you are thinking about but if it is in the highrange you can get very spectacular results from a dual chamber aperiodic cabinet. It is possible to get near critical damping from a modest size cabinet with a speaker in the .4 - .5 range. Instead of the aperiodic vent loaded to the outside of the cabinet it is loaded between the primary small cabinet and the second which is between 1/3 to 1/2 the speakers VAS. You then will get the slower low frequency roll off of a sealed cabinet which would probably be useful for such a small driver. Hezz |
#66 | ||
Davy Jones |
#67 | |
As for the 3" by 5" by 6.5"-I did not realize we got to use the volume of two of those cubes. I believe that if we can do that, we can come up with something even better. Where do you want to cross over to the subwoofer? The normal crossover is generally between 70 to 140 Hz. I wuld suggest the higher crossover, which is still a half octave below's Bose's 200 Hz, since it allows you to make a smaller satellite and cuts way down on intermoduation distortion.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#68 | ||
BTW, I have been assuming there would be no high pass filter built in to the mains.
Davy Jones |
#69 |
Someone earlier mentioned in-walls. I think you should give them some consideration. You can use a real woofer and tweeter and paint the grills so they disappear visually. They should kick serious booty sound-wise compared to any enclosure of the size being discussed here.
#70 | |
| Bose 901 design | 901Fixer | Multi-Way | 33 | 1st April 2013 06:12 PM |
| Harmon Kardon HD-970 modded, a world beater? | Nigel Page | Digital Source | 125 | 16th May 2010 08:06 PM |
| Bose PAS like | raintalk | Multi-Way | 16 | 23rd December 2004 11:32 PM |
| Was Bose right all along? | navin | Multi-Way | 50 | 18th June 2004 02:13 PM |
