Design a Bose-beater
Old 24th June 2012, 01:40 AM   #231
Jimmy154 is online now Jimmy154  United States
Jimmy154's Avatar
Originally Posted by WaVeInFoRm View Post
before this post was somehow reserected, there where no replys since 2006
Was it my fault
I'm actually going to build my own Bose-beater
I got tried of big over complicated speakers.
I had a Bose cubes and sub system once when I was a teenage for about 30 minutes before returning it. I mean it sounded pretty awful, but it wasn't terrible. Unless you consider those synonyms But on the plus side it should be pretty easy to "beat."
You definitely need to make it swivel though. This should negate the lobing/beaming issues one might have. Seems like there are some good 3" candidates for this. They have a kind of rising SPL once they star to beam. Just listen to them both of them 10-20 degrees off axis, so have them around 20-40 degrees with respect to the other driver in that speaker (or set of attached speakers).
If you don't care for high frequencies much this could be a pretty good compact setup, I think. I don't stress about accuracy of sound production much. I like systems that sound the way I like them to sound, especially with lots of tight bass and ability to go loud.
My idea of a nice 2-way is 3" drivers with 15-18" woofers. But I don't have room for pro woofers playing up to 400-500 Hz, so I'm going with the Bose-beater. I might add a tweeter though. I want to look at small speakers in my small apartment
Old 24th June 2012, 02:09 AM   #232
fpitas is offline fpitas  United States
I have a suggestion for an inexpensive, widely available Bose-beater:
Old 24th June 2012, 10:03 AM   #233
dheming is offline dheming  United States
dheming's Avatar
If you can stretch your budget to $80 I highly recommend this approach: Stanley FatMax Xtreme FuBar III
Old 2nd July 2012, 04:42 AM   #234
Jimmy154's Avatar
You guys are meanies
Old 2nd July 2012, 05:04 AM   #235
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
+1
Here are my Bose beaters...
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 2nd July 2012, 03:14 PM   #236
Jimmy154's Avatar
Yeah you're right, those are the exact opposite of Bose speakers.
They have the lowest WAF I have ever seen.
The only thing I can think of that would have less WAF is if you made speakers enclosures out of a dumpster.
Old 2nd July 2012, 09:16 PM   #237
WaVeInFoRm is offline WaVeInFoRm
Not exactly a bose beater... But this is sure to get the job done
http://www.smh.com.au/ffximage/2007/..._470x352,0.jpg
Old 3rd July 2012, 10:00 AM   #238
dublin78 is offline dublin78  United Kingdom
A good bose beater would be to use individual Audience A3 drivers sealed, in place of the satelites, with a good quality subwoofer. Should be amazing, plus high WAF.
If this is over the budget, then consider the Jordan JX6RD drivers.
Regards.
Michael
Old 3rd July 2012, 11:54 AM   #239
RAART is offline RAART  Canada
RAART's Avatar
If that were my wife I would purchase her PSB Imagine Mini and the best thing is that I can live with it too. Add later a sub and you are ready to rock...
Girls find those mini's cute...
Old 3rd November 2012, 08:53 PM   #240
xrk971 is online now xrk971  United States
xrk971's Avatar
I am designing an mp3 boom box using the well regarded TABAQ mass loaded TL but folded into a 9.5 inch cube to basically have a system that gets down to 55 Hz with low cost 3 in full range drivers. Check out this thread TABAQ TL for Tang Band . This has the cute factor that wives may like.
Design a Bose-beaterHide this!Advertise here!
Harmon Kardon HD-970 modded, a world beater? Nigel Page Digital Source 128 15th February 2015 12:20 PM
Bose 901 design 901Fixer Multi-Way 33 1st April 2013 07:12 PM
Bose PAS like raintalk Multi-Way 16 24th December 2004 12:32 AM
Was Bose right all along? navin Multi-Way 50 18th June 2004 03:13 PM
