Design a Bose-beater
Old 25th May 2006, 01:55 AM   #191
Bose(o) is offline Bose(o)  Canada
I do believe I have seen something of the sort on Planet10's site, tl-speakers.com. Or, something like that. Apparently the results were quite good, but I guess WAF of PVC is kind of low. I mean, it is **** pipe.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 25th May 2006, 04:36 AM   #192
enzedone is offline enzedone  New Zealand
enzedone's Avatar
Talking PVC Pipe
Hehehehehe................. yes true. But I'm sure there are lots of funcky coatings out there
Just a thought
Yes planets site is very insperational, now you remeind me.......
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 6th July 2006, 07:48 PM   #193
misterears is offline misterears  United States
I'm bracing myself for a full frontal assault....but....I've been a designer at Bose for over 17yrs now and small is beautiful here so I feel for the questioner but I can't quite reach him:-). Yes, ladies love our small stylish systems but a lot of non-audiophiles do too.
I put and older Bose single cube 5.1 system on the ceiling of my family room for HT use (prewired) and it was simple and the results satisfying. The bass box is inside the closed entertainment cabinet! But I have dual 31 band 1/3 oct EQ on it ($95) so it sounds quite nice for HT. I have custom dipoles in the living room with my stereo system. I'd suggest a Logitech system (they have many) and save the money you'd have spend on Bose (because that's probably the biggest gripe audiophiles have with Bose products). Then take the money you saved and build a line source and even if you're stuck using them in the garage , at least you won't have Bose in the house. Or....submit and buy a Bose Jewel Cube system and delight your girlfriend!
Old 6th July 2006, 07:49 PM   #194
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
You're a very brave man to admit that here!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 6th July 2006, 08:13 PM   #195
chipco3434 is offline chipco3434  United States
Tell it all brother, tell it all. Confess your manifold sins & transgressions.
Old 6th July 2006, 08:34 PM   #196
cheesehead is offline cheesehead  United States
cheesehead's Avatar
Maybe there are none...
I've been following this thread intermittently over its lifetime. While most agree that the B*SE sound is not something we want to imitate, I haven't seen many DIY solutions the size of a small milk carton. (That's 0.25 L to those in the non-measurement-impaired portion of the world.)
Why not? The reason's pretty clear... can't get the bass out of a cube that size. So you've got the mids coming out of the "sub", meaning the bass is localized, yadda yadda yadda.
Maybe, just maybe, our friend the B*SE designer and his colleagues have done a pretty good job given the constraints of size.
That mean I'll buy it? Nope. I think I can extend the WAF to about a 2 L volume.
I won't address the issue of price or advertising claims
Old 6th July 2006, 11:54 PM   #197
Nanook is offline Nanook  Canada
Nanook's Avatar
Default in my sleep....
hmmm, for very little money:
Elf style speakers (could be as easy as TB drivers, etc, $9 each...$2 for enclosures. Binding posts and internal wire will cost you more. call it $90
Panny XR series of recievers if still available (I found one for $300 USD right away)
cheap Panny dvd , $100
some kind of inexpensive poweed sub (not sure if the Pannies came/come with a high power sub out. If not a decent plate amp (available for as little as $40 on the internet). Any number of small subs (a pair of *" subs mounted in a cube of 12" and Isobaric loading... hm again, available rather inexpensively($25 for 2 GOLDWOOD GW-S650/4 ohms. put em in series and invert the phase of one of the drivers) and . As little as $100 fora dvd /audio setup disc...
somehow 3 5 1/4" 7th order bandpass that makes noise just doesn't seem like it would be in the same league..
No Bose bashing, just a different alternative that may represent better value.
How much do them thar Bose systems run?
stew -"A sane man in an insane world appears insane."
Old 7th July 2006, 04:19 AM   #198
The new Bose acoustimass modules aren't of the BP variety. I'm pretty sure the lifestyle systems are a BP type, but not of the old seven order design.
ERTW 4 life!
Old 8th July 2006, 06:11 AM   #199
gvr4ever is offline gvr4ever  United States
Bose has done some neat things in the past. My main complaint is that they are dated and they charge too much. WAY too much.
In the 80s and even the mid 90s, Bose might have been on top of things. For CD and VHS play back, it works pretty well.
The problem with Bose is, you simply have to move air to make big sound. Bose can't do that with small speakers and a tiny sub. Do they have 6' drivers in the sub?
I'm not sure why any DIY speaker builder would want to mess around with trying to make a bose clone. They are not that great. For the price, they are lousy. If R&D got half the money that advertizing got, they might acually be up to date in speaker technology.
Paradigm makes Bose sound like crap. If you can't build speakers, look in to Paradigm. They are probably the cheapest high end speakers you can get without going to the next level. Mono amps, and speakers that cost $$$$$$$$$$$$$$$$$$$$ each.
Old 8th July 2006, 07:42 AM   #200
enzedone's Avatar
Default Bose
Couldn't have put it better gvr4ever. Don't like to put companies down, but they really are behind the times. And the quality.....
Plastic speakers made in Mexico.........please.........
Mine lasted about three years before the sub started falling apart, but hey, I saw the light and ditched them.
Design a Bose-beaterHide this!Advertise here!
Harmon Kardon HD-970 modded, a world beater? Nigel Page Digital Source 128 15th February 2015 11:20 AM
Bose 901 design 901Fixer Multi-Way 33 1st April 2013 06:12 PM
Bose PAS like raintalk Multi-Way 16 23rd December 2004 11:32 PM
Was Bose right all along? navin Multi-Way 50 18th June 2004 02:13 PM
