Design a Bose-beater - Page 11 - diyAudio
Old 3rd April 2005, 09:25 PM   #101
Variac is online now Variac  Costa Rica
diyAudio Editor
Variac's Avatar
The Aura has 5mm+- xmax,
The Hi-Vi is 3mm+-
I think the extra x-max is very important in this case if it allows us to go down to 100hz
Also, I can't tell if either one or both use neo magnets. since we are fighting for space, an extra cubic inch or so due to neo might be well worth it.
This will really help:
You can integrate the stand into the cabinet to pick up some extra volume and still keep the cabinet really small.
A good trick that the Bose guys don't use. Even a 2" dia column would help a lot. And if it is stuffed, I don't think the shape would matter too much, right?
Tiny cubes on elegant slim tubes, -cute indeed, and what an advantage: she can move them around, they don't take up shelf space, they look scuptural.
And we know:
-we get more cabinet volume (1/2" MDF or hardwood would work fine for the cube)
-The speakers won't be put on a shelf where they will sound pretty bad no matter what!
The bases could be wood or metal plates OR : 1" high metal boxes with the amps built in. I guess this would require a power cord- not at all cute - never mind.... WAIT- I've got it! the bases are say 10" cube subwoofer boxes. The sub driver weight balances them, and the box on the floor isn't that noticible, and gets floor loading. If her floor isn't carpeted, the woofer could face down. This would allow crossover at 150hz 'cause the sub is right with the head. If her floor is wood, then the cubes should match it.
Boy! if you could mock these up with say a 5" solid hardwood cube for the "head" with a great finish, a 3' length of 2 1/2" dia. aluminum with a brushed finish, (or painted black if she thinks it's too flashy) (or you could use a 2 1/2" cardboard tube and cover it and spray black) BUT everything would have to have a really nice finish.
and a 10" per side cube on the bottom, and she signed off on it, I think that this could become a classic!
Conservative Column Volume: lessee.... say the internal diameter is 2" in case you decide to go with 2.25" diameter tube with 1/8" walls. Radius 1, 1 squared times 3.14 = about 3 cubic inches per inch of column. a 36" column would have an internal volume of
108 cu inches- about the same as an additional cabinet of about 5x5x8" exterior size. Or: the total cabinet volume would be about
172 cu in. or 2.8 liter or .1 cu ft. hmmmmm, how about it guys?
will the Hi Vi B3N work? With aperiodic loading? Can we do a linkwitz transform to extend the bass so it works in 2.8 l. ?
I guess the crossover point is determined by whether she goes for the sub as a base or not. If she goes for the sub base then the Hivi would work at 150 hz maybe, and the round frame varient is very cute and attractive. If she doesn't like the sub-in-the-base, then the Aura crossed at 100 is prob the way to go.....
... Kelticwiz: seems like your scheme would be fine with this
Maybe the extra volume would allow a 100hz crossover if the sub had to be remote?
These could be great HT speakers for many of us!
"The geek shall inherit the earth"
2016 S.F. Burning Amp Festival To Be Nov. 13
Burning Amp thread here on diyAudio [/B]
Old 3rd April 2005, 10:11 PM   #102
djmiddelkoop's Avatar
It could also be that Mark responds to the posting of DJMiddelkoop, without looking on the website, only the speakers, and because looking only for 5 seconds, he doesn't know that those are ESL's.
Yes indeed, Joris has seen it right, it is noot a cheap Walmart or Kmart system, it is an active sub with 3 ESL's.
The 3rd ESL can be used as center in a surround system.
The ESL measures 10 by 30 cm which is approx 4 by 12 inch.
Dick
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 3rd April 2005, 11:15 PM   #103
Default Jordan JX53
What about Jordan JX53 fullrange? It could be used in a box as small as 0,34 litres. The Jordan website states a frequency range from 100hz to 30khz.
And it is supposed to sound really well, sensitivity is 87,26 db.
Peter
Old 4th April 2005, 01:19 AM   #104
Default Re: Jordan JX53
Peter
I doubt whether a small 0.34 liter box will giv eyou much bass with a driver that size down to 100 Hz. You can use the JX92S in a larger box and get real sub 100 Hz coverage.
On that JX53 sensitivity: That 87 dB is before baffle step compensation. Figure 3-6 dB less sensitivity for BSC with the JX53 in a typical box spaced away from the walls.
Old 4th April 2005, 02:29 AM   #105
Or are you saying that Wal-Mart sells, at $34.95, a better home theater system than Bose-but not one that necesssarily contains the same drivers as the Aura NS-3 or the HiVi B3S?
Yea, I think the Bose system is a piece of junk of which an equivelent Chineese copy can easily be bought for 34.95 at wal-Mart. Its certainly ALOT better than the tiny speakers in my Samsung LCD TV and a better value than the equivelent size Bose product.
Mark
Old 4th April 2005, 03:08 AM   #106
Here's my take on the inexpensive Bose beater. Three inch full range and four inch woofer. Four inch doubles the lower range only to reinforce the bass output from 200 Hz down. The integral stand uprights are used as speaker air volume and stuffed to kill standing waves. 1/2 inch MDF. Only slightly larger than BOSE. 5.5 inches wide by 6.5 deep by 8 high. 3.5 by 5 at top of cabinet. Inner cross partition to seperate four inch from modulating low x-max of three inch full range. Aperiodic loading of upper driver. Lower stands have hidden vent in rear for aperiodic loading of woofer.
Hezz
Old 4th April 2005, 03:33 AM   #107
Also another idea,
If you are forced to use 1/4 inch MDF for the cabinet. Layer the inside and out with one layer of fiberglass cloth and epoxy resin. If a thin brace is used inside this will make the cabinet a lot more ridgid without adding much size or decreasing internal volume.
Hezz
Old 4th April 2005, 03:33 AM   #108
Peter
Might just work. It is just a tiny bit wider than we want, but just about everything is. Everyone please remember, the object of the exercise is to make a system with satellites that are as small as the B-se AM-15. Making a system that just sounds better for the same money (or 1/8th the money) is trivial.
Here is a simulated FR plot of the JX53 in a 57 cu in sealed box. The Qtc is about .95. It looks like you would need to cross it over at 140Hz or more, but, hey, that beats Bo$e!
Davy Jones
Old 4th April 2005, 02:09 PM   #109
What about this:
You could put the jordan JX92S in a 5" cube made of 5mm aluminium, and use an aluminium tube like Variac suggested to increase the internal volume.
Or if you want it to be even smaller, the JX53 in a 3.5"X4.5"X3.5" box.
Hmmm... aluminium cone, aluminium box, aluminium tube, i think that would be cool
Peter
Old 4th April 2005, 06:27 PM   #110
Emprov is offline Emprov  United States
Been lurking for a few months and I'm really getting sucked into this thread. I'm pretty much in the same boat as Dave, 'cept I'm married and therefore have a bit more pressure on me for the asthetics.
I found a Phillips 5:1 for $47 on ebay and it works ok for HT apps, it's really weak for music though -- it's missing all of the low mids and highs and another speaker solution is a definite must. So, I'll be watching things thing with a lot of interest. That's all, just wanted to officially pop my head in and say hi!
Harmon Kardon HD-970 modded, a world beater? Nigel Page Digital Source 128 15th February 2015 12:20 PM
Bose 901 design 901Fixer Multi-Way 33 1st April 2013 07:12 PM
Bose PAS like raintalk Multi-Way 16 24th December 2004 12:32 AM
Was Bose right all along? navin Multi-Way 50 18th June 2004 03:13 PM
Copyright ©1999-2017 diyAudio
