Q-factor of bass reflex port
Old 26th March 2005, 12:27 PM   #1
SSassen is offline SSassen  Netherlands
SSassen's Avatar
Question Q-factor of bass reflex port
Just a quick question; I'm simulating a few enclosures using Speaker Workshop, but I need to know how to calculate the Q-factor of the bass reflex port as that variable needs to be entered for Speaker Workschop to do the simulation.
Any suggestions?
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
Old 26th March 2005, 01:19 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
If you mean Ql then I'm not aware of a way to calculate it, it has to be determined experimentally. 7 is a typical value. My last sub measured at 5.3.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th March 2005, 01:23 PM   #3
SSassen's Avatar
No, not Ql, that's obvious.
Best regards,
Sander Sassen
Old 26th March 2005, 07:00 PM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
Obvious? So what value did you use
The only reference I know of that walks you through the calculations to calculate Ql Qp and Qa - losses due to leakage, port and box, respectively - is JE Benson's "Theory and Design of Loudspeaker Enclosures". The methods for measurement and calculation are not trivial and subject to a great deal of uncertainty if you use the 3 point methods described in the book..
The simplest way to "know" the values you have entered are "correct" is to compare a measured vs simulated impedance curve. Ql (as it descreases) causes the minimum at port resonance to rise - Qp and Qa, respectively, cause the lower and upper peaks to fall as they are decreased.
Proximity of damping material to the speakers and unmodeled effects can have a significant effect on the shape of the curve - so in the end, it is good that the bass response shape is not greatly affected by changes in these parameters over their typical range of values.
Qp, interestingly enough, is variable with level - perhaps obvious to you as well.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 26th March 2005, 08:04 PM   #5
SSassen's Avatar
Ron,
Be nice, he was stating the obvious. As I'm sure you'll know for Ql you can use a rule of thumb, for Qp I don't know of any ballpark figures I can use. It isn't important really, but I'm just trying to have as few unknowns as possible when I design these enclosures, saves me a lot of work afterwards.
Best regards,
Sander Sassen
Old 26th March 2005, 08:15 PM   #6
catapult is offline catapult
The defaults in WinISD are Ql 10, Qa 100, Qp 100.
Ql, leakage losses. These are produced by leaks in enclosure or in driver itself. Generally, this is most dominant loss type in vented boxes. Typical value is 5-20. This is quite impossible to predict before building the actual box. For reasonable quality box, WinISD pro uses Ql of 10 by default.
Qa, absorption losses. These are produced by losses in enclosure. Any stuffing will increase the absorption loss. With no stuffing inside the box, 100 is typical. Heavily stuffed enclosure has this about 3-5.
Qp, port losses. These are produced by port. Port has some resistance (air doesn't actually flow through the port without some friction). Actually, by setting this into very small value, you can turn vented box into closed one!
Old 26th March 2005, 08:26 PM   #7
SSassen's Avatar
Thanks catapult,
Just as a FYI, I use the following rule of thumb for Ql:
Closed box, small < 30-liter : Ql = 20
Closed box, medium < 100-liter : Ql =10
Closed box, large < 300-liter : Ql = 5
Vented box, small < 30-liter : Ql = 7
Vented box, large < 300-liter : Ql = 5
For Qa (box stuffing) I use the following:
No fill : Qa = 100
Minimal : Qa = 50
Normal : Qa = 10
Heavy : Qa = 5
Best regards,
Sander Sassen
Q-factor of bass reflex portHide this!Advertise here!
Bass reflex port question Javachip Multi-Way 12 11th April 2006 12:11 PM
Bass Reflex Port: 46mm where to buy? maf_au Multi-Way 9 28th October 2005 08:41 PM
Tuning bass reflex port beamnet Multi-Way 0 28th September 2005 01:03 PM
Port location in a bass reflex box quasi Multi-Way 24 30th April 2005 03:53 AM
what the max Air velocity of bass reflex port? Audist Multi-Way 4 7th February 2005 08:43 PM
Copyright ©1999-2017 diyAudio
