Hi guys.
absolutley LOVING this forum!!!! still a newbie to diy speakers, but I think i will attempt some rear surrounds as a starter project. I have a couple questions: do places like solen.com typically sell the binding posts and plastic mounts for the posts? again, would solen sell the "tube" that provides porting/venting or what is typically used, just a round hole in the wood? and lastly, as the thread title suggests... I know that a crossover provides some type of high or low pass filtering. but why woudl one do this? is it just when you have more then 1 driver in a cabinet and you want to separate certain frequencies from the drivers? are crossovers absolutely necessary and how do you go about incorportaing them? how do you know your capacitor values?(i assume all you reall need in s crossover is a few caps) |
#2 | ||||||
Hi aarono,
first of all, I strongly recommend that you build an existing, proven design as your first project (there are hundreds of them, if not more - name your demands and people will probably shower you with recommendations). Quote:
Resistors are also very common in filters. The above is applicable to passive crossovers which is what you're most likely to want to deal with. Active crossovers are a different kind of thing. Quote:
There's a whole lot more to crossover design than even the most helpful person could ever cover in a single thread in an online forum. I recommend that you use Google to find ressources that explain at least the basics of the topic. Whether a text book (by Dickason or D'Appolito, for instance) is the right thing for you depends on how deep you're interested in diving into the subject. If you intend to build just one pair of speakers and then move on to other fields of interest, there's probably no point in investing lots of time and effort in learning about (electro/psycho)acoustics, (electro)mechanics, (electric/acoustic/mechanic) filter theory, measurement techniques and stuff like that, since, in general, I don't see a point in trying to design a speaker system on ones own instead of building a proven design, unless having profound knowledge on the whole not so trivial subject or unless being able to enjoy spending time and money for random trial-and-error. On the other hand, if your expectations aren't high and your materials inexpensive, you might well be able, with some help from a forum like this, to get acceptable results. (I'm adding this remark because I'm aware that many beginners already have drivers at their hands with which they don't know what to do.) jpg |
#3 |
The previous posting explains it well enough for the start. Solen - where I source my drivers and x over parts from - also have designs and diagrams on their webpages for some proven diy speakers. Check it out. |
| Role of 10K Resistor on input? | gychang | Class D | 7 | 11th July 2009 07:57 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| The Role of "Experts" on diyAudio ( split from Cap thread) | Christer | Everything Else | 37 | 18th June 2003 05:43 AM |
| Not new, but a new role | planet10 | Introductions | 4 | 20th August 2002 09:46 PM |
| Page generated in 0.09314 seconds (74.85% PHP - 25.15% MySQL) with 10 queries |
