passive radiator ???
Old 25th March 2005, 10:38 PM   #11
bombardon73 is offline bombardon73  Netherlands
Those are PA and instrument loudspeakers.
Beyma is also pretty good and so are some of the PA units of Monacor.
Peerless does have a few PA woofers but Peerless is better in making good hifi loudspeakers.
Old 26th March 2005, 07:24 AM   #12
Ahmad_tbp is offline Ahmad_tbp  United States
o thnx man ...
and what bout higher frq that the woofers cant respond ?? should i use midrange , tweeter etc ???? ...
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 26th March 2005, 08:02 AM   #13
Most of these 10" woofers can be used up to 4 Khz (mid/high frequencies). This is high enough for most bass amplifications, but when you want that transparent slapping sound you may want to add a high frequency horn to it. These horns can be found in many shapes and most of them can handle frequencies from 4 Khz up to 18Khz. But for metal and hardrock I don't think that a highfrequency horn is nessecary. I even think that a good 12" woofer will do the trick for your playing genre, most of these 12" woofer can be used to 2,5 or 3,5 Khz.
Do you play with a pick? or with your fingers.
Old 26th March 2005, 12:21 PM   #14
hi again ...
i m playain w fingers ...
but most of the times i like to play w a high treble & i don think the woofers can handle it ... i like sound like alex webster bass playin if u hear that .. it has treble sound .. & he s playin w fingers but sound like slapin on bass , i donno how to explain it u should here it ur self .. & i just think i may need mid & tweeter for that ...
& what bout power amp ??? should it be PA ???
Old 26th March 2005, 12:55 PM   #15
who s ur favor bassists ?
Old 26th March 2005, 02:00 PM   #16
If he's got a trebly sound you should go for 10" woofers with a horn (bullet) tweeter. Maybe you've seen those cabinets with four 10" woofers and a tweeter in the middle. Thats what you need.
I have lost of favorite players, one of my biggest influences is Les Calypool from Primus.
Old 27th March 2005, 09:46 AM   #17
hi again ... yeah i saw those cabinets ...
so should i use a PA power amp for PA speakers ???
Old 27th March 2005, 09:56 AM   #18
If you got an instrumentpreamp you should use a PA amp. There are lots of amp on the market that are not that expensive.
Also, most PA amps can be used in bridge mode (left and right joined together). I would then go for a PA with at least 2x200 watts (bridge mode 400 watts).
You can't get a hifi amp with the same power for a low price.
Old 27th March 2005, 08:23 PM   #19
.. any idea for a pa amp ???
any pcb lay out ??? ( cuz i cant convert the schmatic ... ) ..???
Old 28th March 2005, 10:49 AM   #20
Maybe you could check the 'solid state' section of the diyaudio forums. I think someone over there will have some schematics for a PA amp. Schematics for amp are not my territory.
passive radiator ???Hide this!Advertise here!
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
Passive Radiator For ESS qdoc Multi-Way 0 8th July 2004 05:06 AM
