Old 23rd March 2005, 08:38 PM   #1
aarono is offline aarono  Canada
Default speaker repair
Hi, I recently inherited a pair of paradigm monitor 3's ( i think thats the model).
pretty big monsters... one of em soudns great. the other doesnt.
i took the grille off and heard (or actually didnt hear) the tweeter was not working.
got a replacement tweeter but still, there was a problem... there was a nasty distorted sound. another look revealed one of the main drivers was damaged.
please excuse my lack of proper terminology, but I will try to describe the damage.
looking at the front of a speaker there are 3 parts... the center dome, the cone that surrounds it, and then a diaphragm like ring that attaches the cone to the speaker frame. in my case, the ring arond the outside is made of a plastic rubber like material. the problem is, it has completely detached from the cone. The speakers are quite old, I suspect the glue just gave away but perhaps a loud blast from the previous owner cause the detachment.
So I'm wondering if this is a kind of repair I could do, or should I just buy a new driver? what kind of glue would be used and how would I ever manage to get the seal just right? or is that really important that it is perfect? the purpose of this ring seems to be to give the cone (and thus the dome) some reflex type action...
any suggestions welcomed.!
Old 23rd March 2005, 09:57 PM   #2
Speakerholic
Cal Weldon's Avatar
I would suggest you take both woofers (main drivers) to your local speaker repair shop and ask them to either reattach or renew your "surrounds"
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th November 2005, 04:30 PM   #3
TrekNut is offline TrekNut  United States
Hi there,
If you're somewhat handy, (ie- a DIY-er) go to http://www.newfoam.com/ and buy
a foam surround kit. It's relatively easy to do and cheap. I've done a couple and had no problems. The kits come complete with good instructions and support if you need it. A word to the wise ... surrounds go bad with time so that other speaker is on its way also .... replace them both and you won't be hassling with the other later.
Later,
TrekNut
Speaker repair.. stevef51 Multi-Way 5 28th October 2008 08:23 PM
Speaker repair patknk939 Multi-Way 17 16th February 2008 09:44 AM
Speaker Repair dscrobe Multi-Way 7 11th October 2007 11:44 AM
speaker repair aarono Multi-Way 2 30th March 2005 08:15 PM
Speaker Repair bhg41088 Multi-Way 0 17th December 2004 12:57 AM
Page generated in 0.12863 seconds (7.99% PHP - 92.01% MySQL) with 10 queries
