Hello all,
A newbie question: I have a ported loudspeaker rated at 89dB sensitivity and using a first order x-over network. I recently decided to replace the tweeter (Vifa, 89dB) with something of better quality. Problem is that the new tweeter is rated at 91dB. Is there a formula to calculate the value of the series resistor required to match the loudness/sensitivity of the new tweeter to that of the old tweeter? Thanks for nay help Ryan |
#2 |
You'll need two resistors, one series & one across.
For a quick view take a look at attenuation here http://www.mhsoft.nl/spk_calc.asp Cheers |
#3 |
Hi Dr. H,
The 2 db advantage of your new tweeter will probably be offset by our ear's lesser sensitivity to higher freq. I have a 96-97db main speaker and a 105db tweet. Second point : the new tweet may have a different operating range than the old one. So check x-over. HOWEVER, for maximum flexibility, get an L-pad. Hope this helps. |
#4 |
Thanks guys,
I have used the tweeter without any adjustments and found it to be too "loud/bright". Greg, the website you suggested is great, thanks, I was able to calculate that I needed a 1.65R series and 30.9R parallel resistor. Do both of these have to be at least 5W? Also, can someone explain why the parallel resisitor is needed, I would've thought that the series R would be enough to achieve the desired 2dB attenuation? |
#5 | |
Davy Jones |
| Matching Tweeter to Woofer & Xover | Higo | Multi-Way | 2 | 3rd January 2011 05:03 PM |
| Advice on matching a HE 12" mid and tweeter | paulspencer | Multi-Way | 17 | 22nd July 2005 10:54 PM |
| amplifier output impedence matching for tweeter | ackcheng | Multi-Way | 0 | 29th June 2005 02:35 AM |
| Matching Drivers | officeboy | Multi-Way | 2 | 22nd January 2004 06:37 PM |
| Matching Drivers? | Scribble | Multi-Way | 8 | 11th January 2003 03:47 PM |
| Page generated in 0.07773 seconds (82.40% PHP - 17.60% MySQL) with 10 queries |
