I have harman/kardon speakers the left does not work. Barely any sound comes out.
I had a friend who knows a lot about computer try to troubleshoot it and he said it is blown. How does one speaker get blown? |
#2 |
Ask Newt Gingrich.
In any case, there are all kinds of things that can fail inside a powered speaker. Open it up, disconnect the driver from the amplifier, then use an AA or AAA battery to see if the driver is still alive. If it's not, you've found the first problem. If it is, it's time to replace that chip amp inside the speaker.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
most every computer speaker set's cabling is less than stellar, you might want to check the cable for breaks in the wire - or "looseness" where the cable enters the speaker.
garage sale - ing my way to some audio bliss... |
| NAD fuses, slow blow or fast blow? | AllCaster | Solid State | 3 | 25th October 2009 06:11 PM |
| Setting power amp so speakers don't blow (help a novice) | drumstruck | Solid State | 0 | 29th May 2009 02:23 AM |
| Kharma's $1-Million Speakers Blow a Hole in Everything | Nordic | Multi-Way | 84 | 5th August 2007 12:36 AM |
| Blow up once, Blow up twice and Blow up somemore | S.C | Chip Amps | 14 | 6th March 2005 12:09 AM |
| Speakers Causing Amps to Blow? | Old Corps | Everything Else | 3 | 1st May 2004 12:03 PM |
| Page generated in 0.07031 seconds (69.37% PHP - 30.63% MySQL) with 10 queries |
