Array wings -- needed with active equalization?
Old 19th March 2005, 03:30 PM   #1
G.L. Tirebiter is offline G.L. Tirebiter  Canada
Default Array wings -- needed with active equalization?
The holes are cut and I'm ready to get serious about my open baffle array. It has 12 NSBs and 32 Dayton 3/4 inch tweeters a side. I have a question about the wings everyone seems to be using on their arrays -- do I need them if I'm going to actively equalize the arrays?
Old 19th March 2005, 04:26 PM   #2
Paul W is offline Paul W  United States
Paul W's Avatar
Wings are not "needed"...but, since they extend the dipole cancellation path, wings can provide considerable reduction in boost/cone excursion/driver distortion. If curved or angled to the rear they also impact diffraction for any monopoles in the system (like tweeters).
Old 19th March 2005, 09:45 PM   #3
nate is offline nate  United States
Great looking dipoles, but which dome midrange are you using??
Old 20th March 2005, 11:50 PM   #4
bear is offline bear
expert in tautology
bear's Avatar
Imho, the "wings" are necessary for optimal frequency response.
If you read Rudie Blondia's website you'll see what the effects on the
response are from the wings... there is no effective means to correct the response due to diffraction effects, which is what you get with sharp edges and "wings" that don't do the right things...
EQ will only effect the response in the axis which you measure - assuming on axis, then the polar response (the response everywhere else) will be "wrong."
So, it's best to get the optimal results from the physical configuration, and hopefully not need any EQ, or very gentle EQ if any...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 21st March 2005, 02:04 PM   #5
Paul W's Avatar
Nate,
Thanks! The mid-domes are Dynaudio D-76AF. (The others are W26, W22, OW-1)
Paul
Array wings -- needed with active equalization?Hide this!Advertise here!
advice needed for cheap line array tweeter zobsky Multi-Way 23 15th September 2009 05:24 PM
active equalization help downward_dog Digital Source 0 3rd June 2005 12:19 AM
Active/Room Equalization sdclc126 Multi-Way 6 24th January 2005 10:13 PM
Why is active equalization "bad"? mr_push_pull Multi-Way 17 21st July 2004 01:06 PM
WTD-Rackmount 'wings' for Ultracurve Pro RobWells Swap Meet 1 6th January 2004 11:04 PM
Copyright ©1999-2017 diyAudio
